Question about NewAir AF-330 Air Cooler Fan
Not very cold, Newair af320
I removed the back...my motor wasn't working and not unplugged. It has to rotate the 'blanket' through the water and since it wasn't getting the blanket wet, the water cooler was working like a fan, and not a very good one. I had noticed that it wasn't evaporating as it said it should in the instruction manuel. I know I could replace the motor, just need to know what kind would be compatable. It hasn't been real warm yet, but I would like to have this up and running before it is. Thank you
3 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: I think the fan on
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 24, 2011
  • 1363 Answers
SOURCE: How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Posted on Sep 10, 2015
How to change a motor on haier top loader
need model for more precise instructions but
generally it's like this
unplug and lay your machine down on it's front, on a blanket or tower.
1) remove motor / brake cover (some have counter weights too)
2) unscrew motor to loosen belt
3) remove belt
4) remove motor
5) replace and reverse list.
you will need a socket set, most of the motors plug in and out easily. make sure your cables go back with ties if needed.
Nov 08, 2013 | Washing Machines
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
94 labaron, the engine has excess vibration, gets worse in reverse. Rencently had the water pump replace, and noticed that at least one of the bolt on the motor mount wasn't replace, possibly two.
Yes, you need the motor mounts checked, all of them. Take it back to whoever did the water pump, or have it done. That must be where all the vibration comes from. The mechanic must have forgotten to tighten everything back up-thats when the engine front mount and bracket would have been removed for the water pump.
May 07, 2012 | Chrysler Cars & Trucks
Whirlpool wed5840sw0 dryer NOT STARTING
not make for large blanket change the white fuse air not going out
Nov 13, 2017 | Whirlpool GEW9250 Electric Dryer
Top Loader LAT9406AAE s/n 23257742UQ Will not operate in any mode
if the washer will not fill I would change the water inlet valve. this could be the problem for all other issues. if the machine has no water in it, likely the timer will not advance to wash.
Oct 27, 2009 | Washing Machines
My daughter put a big blanket int he washer. it started and then after a few minutes it stopped. I had to untangle the blanket after the motor stop working. now it will not even turn on. I am thinking
Hi, When the washer is in spin mode, do you hear the motor running at all. It could be the lid switch has broke. I do not believe it will be a motor.
To test the lid switch, Remove the screws located on the back of the control panel on each end.
Lift the control panel and let it rest on the hinges. The lid switch is located to the left and has a three wire harness. Unplug the washer before you unplug the harness and put an insulated wire between the two gray wires (not the green stipe wire)
If you can jump this, turn the timer back into spin cycle and see if it starts.
Please let me know if it helps or if I can assist you further.
Vic
May 30, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore Series 80 top loading washer that doesn't spin or agitate
Unplug machine, remove water pump and motor, behind the motor is a coupler, take broken parts to your local appliance parts store. Costs 16 bucks, replace the broken parts with new ones, reassemble machine. Never ever do a blanket/comforter in your machine again!!
Mar 31, 2009 | Kenmore 24032\24036 Top Load Washer
Ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Feb 09, 2009 | Ariston Technologies L63 Free-Standing...
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Electric blanket error code
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Mar 25, 2008 | Heating & Cooling
NewAir AF-330 Air Cooler Fan Logo
43 people viewed this question
Top NewAir Dryers Experts
Are you a NewAir Dryer Expert? Answer questions, earn points and help others
