Question about Compaq MPX EN5038B Network Adapter
The Compaq MPX EN5038A Ethernet adapter..
Am i able to install this product even tho i already have a ethernet insert plugin?
  • 1 more comment
  • mcjjely Jun 22, 2009
    yes i was curious to see if its possiable to just installe this hardware then have two ethernet inputs, their is already one on the mother board, and i want another cause i need somewhere to add my xbox live cable into my computer.
  • bebo_micro Oct 02, 2009
    i want this drive
  • raargh May 11, 2010
    Hi; I assume you mean there is already built-in Ethernet on the motherboard. In general, Windows will allow multiple NICs, assuming they are reasonably current and the drivers are available. But, this begs the question - why do you want two nics? Are you trying to turn your PC into a router or something like that? Did the mombo NIC fail?? Raargh
    Sergeant:
  • 137 Answers
Yes. Most operating systems support using more than one Ethernet card simultaneously.
Posted on Oct 21, 2010
Driver for compaq d51s
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver if you see a yellow ? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
the driver could be on the motherboard disk or the one supplied by your ISP internet service supplier or you might need to download it
http://download.cnet.com/compaq-integrated-netflex-adapter/3000-2112_4-10006215.html
or
http://download.cnet.com/compaq-nc3120-fast-ethernet/3000-2112_4-71738.html
hope this helps you
Feb 14, 2012 | Compaq Computers & Internet
Need a driver for the mpx en5038 ethernet card
http://members.driverguide.com/driver/detail.php?driverid=41282&xdl=1&action=downloadsplash&expcode=6IzcmMg4nkAZsTigazDkkTejPoo7VWqBIB863oAIWC0oH5bNk8JjBAKxyeOocCaKhVBtO7wUjkst%2BUZ%2B7FueyvwWOXdFeBKBJVZTOp50QA2MHFVhLmTVSovXK3KC0vcJWz4SjNostixxT6WIrauQnDdzSIj0R%2BUgGpqrunoYOODq2qt5zYmRCYi9xEpWllaJWsc1B4M8369lynDhPYFkMw%3D%3D
link to driver for MPX EN5038B
I hope this helped
Nov 11, 2010 | Compaq MPX EN5038B Network Adapter
Is this adapter a plug and play? or a installation product?
That specific adapter would need to be installed in a PCI slot inside your computer, it is NOT plug and play.
Jun 22, 2009 | Compaq MPX EN5038B Network Adapter
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
Compaq V3828AU driver
download using this link http://xtreview.com/id-506-v-NVidia-WHQL-drivers-update.htm and your problem will be solve
Feb 12, 2009 | Compaq Network adapter
I cant install the ethernet driver on my compaq presario sr1050nx
go to 'support' at www.hp.com and look for dirvers for your model. There should be a driver for the 10/100 tbase ethernet device. Download and install it and reboot. Should fix the problem if the ethernet adapter is working.
Dec 12, 2008 | Compaq Presario SR1050NX (DW257A) PC...
About ethernet
If you computer has already a ethernet card installed on it, just need to get a ethernet cable and connect it to your modem and the other to the computer and make sure the USB is disconnected already, then power off your modem and restart the computer then power the modem back on and check if internet is already working, if its not working you may need to contact your ISP and tell them to enable the ethernet connection of your modem....
Sep 14, 2008 | SMC Abocom ExpressCard to Ethernet Network...
Westell 6100 ethernet
the prob may b with the ethernet adapter on the computer or the ethernet port on the modem or the ethernet cable.....
to check ethernetadaptor  ping 127.0.0.1
to check the ethernet port on the modem...if u plugin the cable u should have a light lid up on the modem ..
to check the ethernet cable  try with an alt cable which is proved to be working
Jul 26, 2008 | Westell Wirespeed LiteLine 6100...
Compaq MPX EN5038B Network Adapter Logo
2,815 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
