Question about Kenmore HE2 Plus Front Load Washer
Drum wont turn and belt disconnected. how to rebelt.
You need to remove the front, place new belt around drum and then over pulley.belt should be tight against drum hold drum with out getting cut and let run while holding it to see if the belt is on correctly if not tryt again. once belt stays on then replace front and your done
Posted on Jun 22, 2009
I have misplaced my manual. I have a Samsung Moisture Sensor dryer. the power works but the it wont tumble. Model #DV400EWHDWR/AA SERIAL # Y6915AEFB00979F. PLEASE HELP.
Samsung has the manual and a trouble-shooting guide on the product support page: http://www.samsung.com/us/support/owners/product/electric-dryers-dv400ewhd . The direct link to the manual is currently http://downloadcenter.samsung.com/content/UM/201501/20150120165209818/HUDSON_DRY_DV456_DC68-03170A-09_AA.pdf .
Usually if the drum won't tumble, the problem is with the belt, the drum rollers, bearings or shaft that the connect the drum to the motor or the motor.
Can you turn the drum by hand easily? Then look closely at the belt. Replace it if it is damaged. If the drum won't turn, disconnect the belt and check if the drum turns. If it doesn't, check the drum support rollers for wear. Replace all of the support bearings at once if any are faulty. Check the support rollers and shaft at the back of the drum for damage. If you hear a lot of noise as you turn the drum, then the bearings are possibly bad. Check that the plastic slides that stabilize the front of the drum are fine.
Finally check the motor. Replace this if it is faulty. To see a parts diagram and price lists for any parts, see http://www.appliancepartspros.com/parts-for-samsung-dv400ewhdwr-aa-0001.html . Other sites also have the parts for the dryer.
I hope this helps.
Aug 12, 2017 | Samsung Dryers
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
Drum dose not turn.
sounds like the belt or motor, need to take it apart, the belt should be in the middle of drum if it is then more the likely it is the motor, you can disconnect belt pug dryer in and see if the motor spins, there may be a reset on the motor, if so it is located where the wire come in. Here is a website that that will help with the cabinet removal and some other things that could cause the problem:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 25, 2010 | Amana ALE643RB Electric Dryer
Put new belt on dryer but it wont turn and i can smell burning and the drum wont turn
sounds like the belt may be bound somewhere, I would take it back apart and see if I can turn everything by hand. If everything turns freely then I would reinsert drum, hook belt up and see it I could turn the drum with my hands, it will turn but not to freely. Hope this helped tim
Sep 19, 2010 | Dryers
Belt broken, drum wont turn manually
if your drum will not turn manually, then the motor is seized up, or a sock is caught in the blower wheel...
Sep 15, 2009 | Dryers
Belt slipping / takes a minute to start tumbling
Before replacing belt check the space between the drum and the front AND rear seals with your fingers for foreign objects caught there. This may make the drum too tight to turn. Belt is usually broken before it needs replacing.
Also check idler pulley next to motor and motor itself with belt off both pulleys making sure they both turn freely. I think something is binding. Check all those BEFORE replacing belt.
Disconnect plug before opening unit.
Aug 21, 2009 | Maytag Dryers
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
Belt broke on GE Dryer model #DDE7500BALWH
You will need a WE12X82P belt, or just a WE12x82 (the P stands for packaged)
  • Disconnect power
  • Remove screws under the front edge of the dryer top
  • Swing top up and remove one screw from each side panel holding the dryer front, near the top of the dryer.
  • Pull dryer front forward a bit and lift off bottom pegs. Swing to the side. (no need to disconnect wires if you don't want to)
  • Put belt around drum, lifting drum a bit to get belt past drum support slides on the bottom side.
  • Check to make sure drum slides are not worn through, especially the one on the left side.
  • The grooved side of the belt touches the drum
  • Belt runs from drum directly to motor pulley on the left side, then around belt tensioning wheel and back to the drum.
  • Turn the drum a revolution or two (counter clockwise) before reassembly.
Oct 04, 2008 | Dryers
Kenmore HE2 Plus Front Load Washer Logo
250 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
