The door on the washing machine is stuck and will not open after it has completed its cycle.
SOURCE: Washing machine door will not open
remove the front kick panel. feel at the back of the door switch, there is a plastic thing with a ring at the bottom, pull this down and you can hear a click at the door switch and you can open it now. that is the manual door opener. make sure there are no more water inside or you'll make a mess.
tnx 4 using fixya,
drcool
SOURCE: washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: Washer will not open after washing cycle ie
You can also try running the reset to see if that clears the latch, but you shouldn't have to do that.
SOURCE: washer completing washing cycle but
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.Hope this solution will fix your problem for sure.
