How to get spec of pc & enchance performance without adding RAM
Hi...hav 2 ques
1.how to get product number & serial num of product?
2.How to enhance the performance of computer without adding RAM?
  • 721 Answers
The serial is on the back of the pc,same for the c.o.a. for windows. For xp you can go to the control panel & change all the settings to low. Things like having the mouse stream,desktop, font smoothness,etc. Also keep the hard drive defragged.
Posted on Jun 22, 2009
  • 508 Answers
If your running windows this is an excellent book http://www.amazon.com/Hacking-Windows-ExtremeTech-Steve-Sinchak/dp/0764569295 there should be a tag on puter usually on back,also heres and excellent guage to tell what your computer is doing http://download.cnet.com/PowwwerSoft-CPU-Monitor/3000-2072_4-10380594.html
HELP ME I'AM uses photoshop CS3 my serial num:1045-1090-6246-8353-3166-2968 ACTIVATION NUM: 1362-3657-4334-4061-0742-3142-4063 SO AUTHORIZATION NUM ??????????????????????????????????????????????
You should take this down very soon, your serial number is unique and could be used by someone else. If the installer is not accepting either one of these numbers than you should call into adobes phone support activation.
Mar 21, 2011 | Adobe Photoshop® CS3 Extended Full Version...
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
My pc have not 1GB ram, so i want install Adobe Photoshop CS2, by i have not Adobe Photoshop CS2 serial num. what i do?
the serial number of adobe photoshop CS 2 is
1045-0436-9551-0266-5984-9386 1045-1756-2071-0999-3438-3575 AND you can download the adobe photoshop CS 2 from following link
http://www.brothersoft.com/downloads/adobe-photoshop-cs2.html
Jan 05, 2011 | Adobe Photoshop CS2 for PC
Today without any warning, after i started my pc, when it load until the window loading screen, suddenly the screen turn pitch black & a loud continuous beeping sound was started. I tried to trace...
Try it with 1 gb memory if it still beeps, try it on a different slots. if it works with 1gb turn off the pc, slowly add the other rams then test
Aug 23, 2010 | Computers & Internet
I need to know more about a Gateway Performance 800 motherboard. I added a second 128 meg SDRAM 100 Mhz simm in bank 1 (the board came with a simm in bank 0). The BIOS recognizes the original simm as 128...
Check the specs for your new ram. It sounds like you have double density ram installed. If your motherboard only supports single density it will only see 1/2 of the modual hence 64meg showing for 128 stick.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 11, 2010 | Gateway Performance 800 PC Desktop
Ram compatibility
No Sir, it will only support DDR / SD RAM. You can see the complete specs of your Board here.
If i was helpful, kindly do Rate! Regards.
Jul 31, 2009 | Computers & Internet
Just wanted to know if the mother board 865GM3-LS supports 1Ghz of AGP graphics card..
Motherboard has a AGP 8x ( 1.5 V/ 0.8 V ) slot.
Check the specs on the graphics board you are going to install. Make sure that it meets these specs.
Here are the specs for your motherboard: General Product Type Motherboard Form Factor Micro ATX Width 24.5 cm Depth 24.5 cm Compatible Processors Pentium 4, Pentium 4 Extreme Edition 64-bit Processors Compatibility Built-in Processor Socket Socket 478 Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz BIOS Type Award Storage Controller ATA-100, Serial ATA-150 Processor Installed Qty (Max Supported) 0 ( 1 ) Memory Supported RAM Technology DDR SDRAM RAM Installed ( Max ) 0 MB / 2 GB (max) Supported RAM Speed PC2100, PC2700, PC3200 RAM Features Two DDR channels Video Graphics Controller Intel Extreme Graphics 2 Video Memory Shared Video Memory (UMA) Audio Audio Output Sound card Signal Processor Intel 865G Audio Codec Realtek ALC655 Sound Output Mode 5.1 channel surround Compliant Standards AC '97 Telecom / Networking Networking Network adapter - Realtek RTL8100C - Ethernet, Fast Ethernet Features BIOS Features Hyper-Threading Technology Expansion / Connectivity Expansion Slot(s) 1 ( 1 ) x processor - Socket 478
2 ( 2 ) x memory ( 2.5 V ) - DIMM 184-PIN
1 ( 1 ) x AGP 8x ( 1.5 V/ 0.8 V )
3 ( 3 ) x PCI ( 3.3 V/ 5 V ) Storage Interfaces Serial ATA-150 - connector(s): 2 x 7pin Serial ATA
ATA-100 - connector(s): 2 x 40pin IDC Interfaces 1 x storage - floppy interface - 34 PIN IDC
1 x serial - RS-232 - 9 pin D-Sub (DB-9)
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
4 x Hi-Speed USB - 4 PIN USB Type A
1 x audio - line-In - mini-phone stereo 3.5 mm
1 x audio - line-out - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone 3.5mm
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
1 x mouse - generic - 6 pin mini-DIN (PS/2 style) Additional Connectors (Optional) 4 x Hi-Speed USB Miscellaneous Software Included Drivers & Utilities Compliant Standards Plug and Play
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 10, 2009 | Computers & Internet
Adding Ram
The RAM should be fine running along side each other but make sure you check the motherboard specs install the RAM leave running for 5-6 hours see how it goes also try memtest86 on your system here is the link
http://www.memtest86.com/
Regards,
Spud
Jun 18, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
