Question about Atd Tools R134a Economy Brass Manifold Gauge Set - ATD-3687
How to readR134A ac manifold gauges
A/C R134A Manifold gauges
How do you read R134A a/c manifold gauges
  • 253 Answers
The blue gauge is the low side. It should read between 30 to 60 PSI depending on temprature. The red is the high side, and should read roughly 3 times the outside temp. Good Luck
Posted on Jun 22, 2009
96 GMC Sierra C1500 Updated a/c replaced compressor, suction/discharge hose, condenser, accumulator, low & high pressure switch cycle switch, flushed evaporator. vacuum 29 inches. R134A will not load.
not mentioned but did you replace with equipment specific for r134a gas
are you connected to the suction line and are sucking gas not liquid
are you using the duel gauge ,3 hosed manifold for the charging process or have you just connected the bottle and hoping for the best
take it to a qualified ac specialist shop
Apr 30, 2018 | GMC Cars & Trucks
How and where to add freon to a1995 sedan deville
Verify ambient temperature is above 65 degrees F.
1. Safety> - safety glasses, long sleeves and gloves, (exposure to refrigerant can cause frostbite).
2. Attach hoses to manifold> assembly, (hi, lo, and fill).
3. Remove caps from service ports, (Low press. Larger tube from evaporator to accumulator - passenger side over fender well; High Pressure - smaller tube from evaporator along firewall towards driver's side). Verify service> ports are clean.
4. Attach low press. and high press hoses to proper service ports.
5. Start car>, reset low refrig code, and turn ac on high and fan on high.
6. Read gauges and compare with chart provided with gauge set.
7. If low and high press readings are both low, then system needs recharge.
8. To recharge, attach fill hose to can of R134a and slowly open low press valve>, (NOT HIGH PRESS VALVE), until low press side reads 40 psi.
9. When flow stops and pressures stabilize close valves> and disconnect manifold from service ports and refrigerant can. Replace service port caps.
Aug 19, 2015 | 1995 Cadillac DeVille
How much freon needed
It doesn't take freon, it takes R134A. There should be a sticker in the engine compartment that tells the amount. but when filling low side should be somewhere between 25-45 and high side 150-300. if you are serious about charging your own system please purchase a set of manifold gauges. it is the only way to properly charge the system. Harbor freight tools has a set for $45 and big lots sells refrigerant for $6. using the pregauged cans to fill your system is a hack way to do it and can be harmful to your ac system. Properly charging the system has a direct relationship to the outside ambient temperature and you can find a R134A reference chart on google images with a simple search. Good luck and also there are some pretty good videos on youtube about using manifold gauges and recharging refrigerant.
Jun 28, 2013 | 2005 Hyundai Santa Fe
How o you add r134a
by using manifold gauge. and must read on it, 38psi for the low side and 180psi for the high side.
Aug 20, 2012 | Cars & Trucks
When i turn on the a/c,the compressor does not work
CHECK REFRIGERANT CHARGE. USING A MANIFOLD GAUGE SET. HOOK MANIFOLD GAUGE SET TO LOW PRESSURE PORT AND HIGH PRESSURE SIDE PORT. LOW SIDE PRESSURE SIDE SHOULD HAVE 25 - 36 PSI AND HIGH PRESSURE SIDE SHOULD BE 178 - 237 PSI. IF LOW SIDE PRESSURE SIDE READ BELOW 20 PSI THE LOW PRESSURE SWITCH WILL NOT TURN ON THE AC COMPRESSOR CLUTCH NEED TO ADD LITTLE MORE REFRIGERANT. IF REFRIGERANT LEVEL CORRECT CHECK AC COMPRESSOR FUSE AND RELAY.IF POWER GOING TO AC COMPRESSOR CLUTCH YOUR COMPRESSOR CLUTCH HAS OPEN WINDING. AC COMPRESSOR CLUTCH NEED REPLACING.
Aug 11, 2011 | 1997 Nissan Pathfinder
Ok i jus buy a ac chek presure manifold, i wanna recharge mi ac carcompresor but the manual donat said how conect tha house in the r134a can, just said how to chek the presur,, can some one help me with...
To connect the hose to the can, it should have a locking ring with a valve. Some connectors screw on clockwise, and others snap on and clamp downward with a locking lever. To open the can, just turn the T valve down clockwise. To release the freon into the hose, turn the valve to the left. Never remove can from the valve assembly, until the can is empty. If you have no clamp and valve for the freon, just a hose, you can buy one at your local auto parts store
Jul 30, 2011 | Mountain R134A Brass Manifold Gauge Set...
Is there a universal gauge set for all types refrigerant
The most common manifold are only for r-12 and R134A. Because of the pressure differences between that and R22 and R-410A ( and the manufactors make more money by keeping the types of manifolds seperate). I haven't seen a universal manifold that would cover all types freon.
Feb 05, 2011 | Robinair R-134a Manifold Gauge Set A/c...
How do i hook my manifold gauges to my residental condensing unit to check pressures
The AC manifold gauges set have the three chambers: the low pressure chamber (left side), utility chamber (middle), and the high pressure chamber (right side).
When technicians connect the HVAC manifold gauge to the air conditioner units, he connects the low pressure side of air conditioner unit to low pressure gauge side.
If he wants to read the pressure in discharge line he connects the high pressure gauge hose to the air conditioner high pressure side.
The utility port (the middle chamber) is a place you connect the hose to vacuum pump, recovery units or add or remove refrigerant from AC units.
Air conditioning gauges is used to measure air conditioner units pressure within closed-system to evaluate or troubleshoot the AC units. Gauges manifold set is the most frequently used item when it comes to refrigerant or pressure.
Air conditioning gauge set allows the HVAC technician to check AC units operating pressures, transfer AC refrigerant, pressure test system, purge the system with nitrogen, and perform other necessary tasks.
The gauges manifold set includes the hoses, the manifold, the valves, the compound gauge (low pressure gauges) and high pressure gauge.
Jul 24, 2010 | Heating & Cooling
On my 2003 Chevy Silverado, the A/C compressor won't kick on. Just blows out warm/hot air.
The ac system may need freon added,if the system is low,or out of freon,it will not allow the ac compressor to come on.
Apr 11, 2010 | 2003 Chevrolet Silverado 2500HD
Atd Tools R134a Economy Brass Manifold Gauge Set - ATD-3687 Logo
888 people viewed this question
Top Atd Tools Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Atd Tools Measuring Tool and Sensor Expert? Answer questions, earn points and help others
