Question about Rockford Fosgate RFX-9000 CD Player
I have a rfx 9000 manufactured in 2001 and i dont see the place for the orange "illume" wire. where would i connect this wire to?
  • 578 Answers
That wire is optional dont really need to use i would not worry about it just tape it up safely and leave it
Posted on Jun 26, 2009
Screen is blank
check the wiring again for the illum.(usally the orange wire) make sure it is hooked up and dash lights are on high.
May 09, 2012 | Alpine IVA-W505 Car DVD Player
I need to know wat the orange wire is on a 2004 dodge ram 1500 stereo
If it is an orange wire with white trace, this wire is used for dimming the brightness when you turn the lights on.....normally connected to the illumation wire...sometimes to the cig lighter illumination or dah illumation wiring........
Dec 20, 2010 | 2004 Dodge Ram 2500
Old m reg escort 16v interior red light on clock stays on - ??
sounds like the clock is wired to the +12v from the stereo instead of ILLUM from the ignition, this light should only come on with the headlights... Connect the wire from the clock bulb to ILLUM on the stereo wiring - I cant find an escort manual so youll have to find which wire is clock power and which one is clock lighting, nedless to say you leave the clock power and ground as they are - just cut the lighting wire and attatch it to the ILLUM for the stereo with a crimp or block connector. ...
tape up everything you leave disconnected.
now the light will only come on with dipped or beam lights, not just all the time on its own.
Jan 16, 2010 | 1998 Ford Escort
Rockford fosgate installation?
The best way to install a stereo deck is go get yourself a Scoshe wiring harness. This will allow you to wire the harness directly to the stereo, then plug directly in to the OEM wiring clip that is plugged into the factory stereo. It helps if and when you sell the truck and want to put the factory stereo back in. Plus you dont have to hack up wires. Hope it helps. You can get the wiring harness from any car stereo installation or customization shop.
Jul 27, 2009 | Rockford Fosgate RFX-9000 CD Player
Installed new CD deck in 07 Corolla, may have shorted something
first check the illumation fuse which to toyota its the panel fuse, check if it is blown. if not take the aftermarket wire harness u wired in with the radio harness and disconnect the orange wire (illumation wire) and see if u have lights again. sometimes the aftermarket orange wire won't work with toyota vehicles. good luck
Jun 25, 2009 | 2007 Toyota Corolla
Dash lights wont work
Some Honda vehicles illumation wire (orange wire)is switched ground. Once connected, turning your lights on will blow your 'small lights' fuse which is a constant power fuse that should be located under the hood. you should just cap off (do not connect) the orange wire and replace the fuse.
May 20, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Rockford Fosgate deck: RFX-9000
You could have a power problem here.
Makre sure you still have 12v on both the yellow and red wire in the loom.
Apr 16, 2008 | JVC KD-LH7R CD Player
STILL HAVIN TROUBLE
"WHICH COLOR WIRE SAVE THE SETTING" - yellow must be connected to an always on B+12 such as the positive terminal of the battery and
red to a switched B+12 such as the ACC terminal of the IGN switch
orange goes to the park/instrument light
Mar 28, 2008 | Pioneer Premier DEH-P580MP CD Player
Rockford fosgate rfx-9200
If you're talking about the amplifier's power terminals, the positive terminal is designed to be wired directly to the battery (be sure to fuse the amp power wire near the battery terminal). The negative terminal should be bolted to vehicle chassis metal for a ground connection. The only amplifier connections that go to the back of the head unit are the remote turn-on wire and the RCA cables.
Aug 16, 2007 | Rockford Fosgate RFX-9200 CD Player
Rockford Fosgate RFX-9000 CD Player Logo
83 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
