Question about PC Laptops
Dell Latitude 500 - Battery vs Power Supply Problem
I bought my Dell Latitude 500 approx. four years ago and have only used it less than 20 times; I use a dual-drive desktop. Shortly after I received it I had problems charging the battery and, via telephone tech support, Dell support determined that it was a defective battery and it was replaced.
A couple years passed before I used the laptop again and when I did I had the same power problem. This was right around the time that there was the massive battery recall... I checked and my battery was not one of the ones recalled.
My laptop seemed to be "dogging" in the power sense. I always had to use it with the power cord attached and the orange battery icon was always on. Last week I installed a new battery and my laptop stayed on for
approximately 10 minutes then it went dead. Even when I plugged the power cord in there is no power going to the laptop.
Could it be my AC adapter? And if so, is it a 65 or 90 watt? Even on Dell's site it shows that both are compatible, which makes no sense. The bottom of the laptop says it can use with either adapter model PA-10 or PA-12.
Thanks very much for any insights you might have.
Re: Dell Latitude 500 - Battery vs Power Supply Problem
I had the same problem and your solution worked!! THANKS!
Posted on Jan 21, 2008
  • 324 Answers
As far as which adapter to use, either should work fine. The 90 watt will run cooler. I have seen the 65 watt go up in smoke when being used on a continuous basis.
As to the battery not charging, unfortunately, it sounds like you may have a problem with the internal power supply. The orange light is showing that the battery is discharged. If this light doesn't turn green after the laptop has been plugged in for a couple of hours, you are not getting the battery charged. Power the laptop down, remove the battery. Check the contacts on both the battery and laptop battery connector for any foreign material or "Gunk" and for any bent or broken contacts.
Hope this helps!
Posted on Nov 03, 2007
0 characters
3 Points
It will not power up battery or ac current. Installed battery 4 months ago it worked as long as battery had power.
You should replace your power supply. If it is possible, try with another power supply or try your power supply in another computer. If the power supply works well with another computer, it has to be a defective motherboard or power board on your notebook.
Oct 31, 2011 | Dell Latitude D600 Notebook
My Dell D505 Latitude will not power up. The 3 green lights flash for less than a second and then it switches off. It was working fine until a few days ago. Any ideas of how to fix this as all my work is...
Sounds like ether a blown power supply. That happens when the laptop battery has alittle juice left.
Try to take out the battery from the bottom and plug the laptop in the wall. If the laptop powers up you battery needs to be replaced. If it doesn't power up, you need to replace the power supply.
Good Luck,
Aug 23, 2011 | Dell Latitude D505 Notebook
I bought a dell latitude but it was password protected and i dont have it any suggestion
I'd put Linux on it.
That computer is about 5 years old. Linux works very well with old computers.
Takes up less space, uses less processor power to run, and comes with free versions of pretty much everything.
I don't even think a current version of windows will install on a 5 year old Dell. So you'd be stuck with out of date anti-virus and no updates.
Boot off the Ubuntu disk and just wipe windows.
Aug 20, 2011 | Dell Latitude D520 - Celeron Intel Celeron...
Dell Latitude D505 won't turn on
hello there this could be alot of things ,please check battery ,also check power supply make sure both of these are functionable ,remove the battery and just connect the power supply and see will it turn on you should have power now ,if not you may replace the power supply please check these with other pc igf you can this will allimanate if it faulty or not ,on the other hand it could be the bios but more than likely its just a power problem ,please let me know goodlook
Mar 26, 2011 | Dell Latitude D505 Notebook
Latitude D600 PC Notebook: I have Dell Latitude D830 and its battery now flas...
Probably. Look for a replacement battery on eBay. I have threee d600s and about a year ago I bought aftermarket batteries on eBay that work fine for about 1/3 the cost of a genuine Dell.
May 18, 2010 | Dell Latitude D600 Notebook
My dell d505 latitude laptop has the dreaded
Sounds like your battery is dead. They go bad in laptops and need to be replaced in a couple years.
1) Unplug your battery and power laptop on with just AC adaptor. If laptop runs normal then you need to replace battery.
2) If it doesnt turn on at all then your motherboard may have a problem. The power supply is integrated on MB on most/all laptops.
2) if you need a motherboard replacement, try
Nov 25, 2009 | Dell Latitude D505 Notebook
Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Mar 11, 2009 | Dell Latitude D600 Notebook
Battery Not Charging
Sounds like the power supply has gone bad. You should get a new power supply. You will get this message when he power supply goes bad
Feb 12, 2009 | Dell Inspiron 640m PC Notebook
External hard drive
Yes, no problems, if the USB hard drive draws too much power you will need to attach an external power supply, usually the small laptop 21/2" drivers don't need external power supplies.
Jan 10, 2009 | Dell Latitude C610 Notebook
Dell d620 will not go into charge mode
This is usually caused by a bad battery. Sounds like both batteries are not working properly. They may still hold some charge, but they are wearing out. After all, they are batteries, and bateries wear out. Keep in mind that some batteries are better than others, even though they may be the same brand, some will hold a charge longer, and some wear out faster. I'm on my second new battery in a year and a half on my Dell, the first held a great charge but wore out after approx 8 months, the one I'm using now still charges fine but only last about an hour and 15 mins.
Jun 21, 2008 | Dell Latitude D620 Notebook
PC Laptops Logo
460 people viewed this question
Top PC Laptops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Laptop Expert? Answer questions, earn points and help others
