Question about Kodak EasyShare C875 Digital Camera
My battery spring won't close!
I was off on vacation and when I went to switch my batteries the spring (or something) broke. I can't seem to get it shut off!
    Brigadier General:
  • 4,090 Answers
Not fixable outside workshop. repair by camera shop and claoim on insurance
Posted on Jun 22, 2009
Problem with Sterling and Noble clock.....went on vacation....apparently if the battery dies the clock is no longer useable....this seems to be what happened?.....please advise
Well that doesn't make sense. How can you change a battery before it dies and not lose power? Just replace the battery.
Search brings up nothing on this. Most manuals are available online if you know the model
Sterling and Noble clock battery died Google Search
Feb 18, 2018 | Sterling Home
Why my APC BR500c ups makes continuous ticking noise when i switch on after a short break in use ?
Are you getting any warning lights? Your post seems to state that this unit is not very old? If still under warranty contact APC, they have fantastic customer service.
Jun 19, 2015 | APC Computers & Internet
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
GTH2548 drive spring broke and I replaced it. Tractor would not start. Replaced battery, start switch, seat switch and PTO switch. Tractor will now start and runs well. However, when PTO switch is...
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Sep 08, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
I have a 2004 Pontiac Sunfire. The battery to my
first you should double check to make sure the batteries are installed correctly ,then get the new car manual out of the glove box ,and check for the reprogram procedure for your remote . every car manufacture has there own procedure , example,I have 03 mustang mach 1 the procedure goes something like this.turn key to on position..put drivers side window up then down open and close driver door then turn lights on and off then radio on off and so on
Jan 05, 2010 | 2004 Pontiac Sunfire
I went to vacation for a month and tried to restart my car, no luck. Also tried using jump start still no luck,(BMW 325i -2004) Please advice
Is it turning over at all or is the starter at least clicking? Check the water in the battery if it has removable caps. If the water is low then fill it with distilled water. If the battery went too far down on juice it may have a dead cell and need to be replaced. You could try a slow charge for 24 hours and see if the battery makes a recovery. They make a little solar trickle charger that has a solar panel that goes on your dash and has a cigarrete lighter plug. Something like this can keep your battery from dying when on long vacations. If the car is in the garage it comes with a long cord to run the panel outside.
Sep 13, 2009 | BMW 325 Cars & Trucks
My Olympus Digital Camera Stylus 850 SW is supposedly waterproof, and shockproof, but when i went on vacation, and took it into the water park, and inside the water. It broke. Water got into it even though...
Is it under warranty?
I would be trying to make a claim against it for NOT being waterproof. If they don't come to the party and replace it you could threaten to sue for false advertising, Contact Olympus I am sure they woulde want to investigate it
Aug 13, 2009 | Cameras
Battery connectors broke
Hey there NewYork691,
I'm from Long Island. The name is Mike and I may be able to give you a more economical solution.
From your description, it sounds like one of the contact that connect the (+) of one battery to the (-) of the next battery broke. If that's what happened, no worries, you'll be fixed in no time.
Find yourself a penlight, remote or any other device that uses AA batteries that you aren't going to miss. Open up the battery compartment and remove one of the spring contacts.
You may have to hunt around to find something similar, but all it has to do is fit in and make contact. The compartment cover will hold the batteries in.
You should be back in business.
Mike
Dec 06, 2008 | Futaba Toys
Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Oct 07, 2008 | Kodak EasyShare DX7630 Digital Camera
Battery/memory card compartment wont close
Don't force it. It could be that your memory card is in backwards. This is a common cause for your battery door to not shut.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
41 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
