Question about Coleman Powermate Powermate 5000W Generator
Ust gg5500 dc power
The dc power dosen't not work breaker didn't trip
  • 98 Answers
Trace your DC outlets backwards...they go to a certain (device)like object...test the wires goint to that device for voltage..if there was voltage then that device is burnt...you can take it to a parts selling shop and buy a new one.
Posted on Oct 27, 2009
UST generator model # GG5500 runs fine no power output
Don't worry I'm sure you will get the solution of your problem, just check the link I attach Best Manuals
Sep 07, 2017 | Electrical Supplies
Does a UST 5500w generator has a AVR. And if yes where is it located? Thanks for the help.
The contact number for parts and service is 1-866-797-2738.
The manual with parts is here: http://www.searspartsdirect.com/partsdirect/user-manuals/GG5500-UST-GENERATOR-manual
And it does not look like it has an AVR
Oct 07, 2016 | Electrical Supplies
Intertherm
didn`t mentioned if there is an stand bye light present on front cover.anyway,if there`s no power at all,check first your crkt breaker if it was on a tripped mode,try to reset it,if it works fine,but if it still tripping off,leave it to the technicians for servicing
Apr 19, 2014 | Heating & Cooling
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 31, 2012 | Electrical Supplies
I tripped a circuit breaker but a reset didn't resolve power to the outlets. I replaced cgi outlet hoping that would resolve the issue but it didn't. What is the problem and/or issue? Can&#
I believe you are referring to a GFCI receptacle. Did
you have power at the GFCI Location? If so, make sure
you wire the line and load portion of the GFCI unit properly.
Jul 31, 2012 | Electrical Supplies
Last night our power popped off and right back on. Now the fan/lights wont work
check to be sure the breaker in your house panel didn't trip,, turn them off all the way , and back on,, sometimes all or just one will trip, and still look like they are still on
Jul 02, 2011 | Hunter (25417) Ceiling Fan
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
I have a UST GG5500 portable generator and it will not produce electricity. The engine starts fine but it doesnt generate any power.
Check your circuit breakers to see if they are tripped or damaged. Then take a look in the end of alternator / generator at the field windings. Check for damage to the brushes, as well as the diode for continuity in 1 direction only. Look for damaged capacitor regulator. Replace as needed.
May 15, 2010 | Electrical Supplies
UST GG5500 generator no A/C output when I first start
Plug something into the outlet and have the breaker on when you start the generator. If it has an automatic idle control, turn that on too. A load will energise the generator.
May 02, 2009 | Northern Tool Dual Turbo Propane Torch Kit
Coleman Powermate Powermate 5000W Generator Logo
209 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
