Question about Kenmore 22422 Top Load Washer
Cold water fill hose seems clogged --will fill hot water fast, but not cold ---very slow drip
  • Kenmore Master
  • 1,262 Answers
There are sometimes, a screen in the hose at the inlet where it hooks up to the "Fauct" per se. You may be able to just clean it and be back in business with no cost.
Washerstu is right about swapping the hoses around to see if the problem follows the hose. If so, replace the hose. If not, you may have some trash or other restriction in the water solenoid vavle.
Good luck
Posted on Jun 22, 2009
  • 31 Answers
Take your cold water pipe off and see if there is any thing in there or it could be your inlet valve broke not had to fix swop them round and if fixs you problem just put a new cold 1 on
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Cold water drips in instead of fills. Hot water
Inlet screen in the hot water hose is clogged (check at both ends) or the solenoid valve has failed.
Oct 30, 2009 | Kenmore 22422 Top Load Washer
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
No cold water
Check the strainer in the hose where it connects to the faucet.  If it is clogged it will slow the water flow.  There may also be a strainer at the end of the hose that connects to the washer.
May 30, 2009 | Washing Machines
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
The cold water does not run it trickles, hot water runs very fast
If both solenoid coils check the same, you probably have a clogged supply hose. Check that the filter screens inside the hose (if present) and the fill valve inlet are clear of mineral buildup. Try switching the hot and cold supply lines to see if the trouble moves from cold to hot. If the cold still only trickles in, replace the fill valve.
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite washing machine will not fill as fast as usual.
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Dec 17, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 22422 Top Load Washer Logo
87 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
