Question about Samsung (MP0804H) 80 GB Hard Drive
Portable HDD stopped working and not recognized
My 2.5 HDD stopped working, tried lots of computers, another USB/HDD adapter nothing helps. You can hear little squick squick sound when plugged (trying to spin?) - but then my Targa USB adapter LED will start flashing and PC cannot see it. Is there anything else can be done?please help.
  • tedvic Jun 22, 2009
    Mm - already tried on lots of computers see original post - so besides going to data recovery centre - any hdd experts here , who might know what the recovery centres do to get the data out?
  • 508 Answers
Sounds like hardrive maybe bad try on another computer! Good luck!!!
Posted on Jun 22, 2009
How can I retrieve saved data from my Transcend 2.5 StoreJet Portable HDD
Remove the drive and connect it to a known good USB adapter. If it still won't be recognised, buy a new drive. Sorry.
Jul 19, 2014 | Transcend 1TB 2.5 Inch StoreJet Mobile H2...
Verbatim portable hard drive has stopped being recognized by my lap top
try pluging in HDD to another computer to see if problem is with HDD or with your laptop, if HDD works OK with another computer that laptop has an issue
Sep 24, 2013 | Verbatim Electronics - Others
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
My Maxtor One Touch III external hard disk has suddenly stopped getting recognized on my laptop. I am using a Windows XP, SP 2 OS. The system is unable to recognize the USB device. Can someone please help?
Check power of HDD, that problem can usually manifest because some of your usb ports can't send enough Volts to your device, restart your machine, check connections, and it should work again as charm :)))
Please rate my solution, thank you :)
Apr 13, 2011 | Maxtor OneTouch III (T01H300) Hard Drive
Hitachi SimgpleTOUGH 320GB portable HDD - Not recognized
Make sure you are using the right USB cable. Also try on a different USB port (preferred one on the back of the PC)
Can you see the HDD on "Disk Management?"
Also if you hear any clicking sound then the HDD has become faulty.
All the best!
Aug 10, 2009 | Computers & Internet
Computer does not recognize simpletech
Assuming Windows, try the Device Manager and see if the (old) disk is listed there in the disk drives section.
If so, right-click it and select Uninstall. (do this while the new driver is disconnected)
That should force Windows to recognize and reinstall the new drive when you plug it again.
For other causes check out the external hard disk problems.
Apr 20, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech external portable drive not working due to power surge
Then you should not connect the adapter, I think your HDD is fried, because these HDDs are USB powered, they do not need any extra power. That’s why HDD data cable comes with two USB 2 pins , one is for data and other is purely for power.
Mar 17, 2009 | Computers & Internet
Need to replace hdd but cant copy old one
The Drives Reader arm Is Either Stuck Or Knocked Off Track And Can' Pass Over The Platters... The Hard Drive Will Need To Be Opened Up And Inspected/Repaired Before Data Can Be Retrieved..
You would hear a ticking or knocking sound if the arm is not working right.. If It Sounds Like its Running Properly You Might Have Erased Data by Scratching The Platters, You Can Try Using A Software Named.. Recover My Files..... And Do A Low Level Search, If THere's any life in the drive, This Program will find the data.....
Feb 07, 2009 | Toshiba Satellite A135 Notebook
Hard drive not recognized by vista or xp
Did you go to microsoft and try to see if you could update any drivers or software that might help you? it's free (microsoft.com) It couldn't hurt to try, have microsoft scan for updates, and it will come up with a list of what's needed or required. Also on your computer, under control panel, updates, make sure you turn off automatic install and allow you to pick what you would like to install. hope it helps, e-mail at tallcoolone100@yahoo.com
Jan 10, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
External hard drive
There is no enough power in you USB port. I was have similar problem with my old PC (Duron 1.3GHz, I don't know what motherboard).
When I conected HDD (My passport Essential) to USB (there is only USB 1.1 port on this MB, and probably if you have USB 2.0 you will have no problem), hardware wizard is started, looking for drivers (which are not needed to install portable HDD), and then I have message like "unrecognized USB device ...".
SOLUTION: On this MB there is 6 USB 1.1 ports, but only 2 are connected on case (with plugs on case outside), others are on MB and if you have cable you can use it. In my BIOS all 6 were turned on, and I think there must be a problem with power on chip (you have some power divided with 6 ports, and this is not enough for HDD).
I turned off my other USB ports in BIOS, and left only fist two, and HDD is now in my computer ....
May 26, 2008 | Dell Inspiron 5160 Notebook
Samsung (MP0804H) 80 GB Hard Drive Logo
673 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
