SOURCE: freezer working fine cooler freeze's when turned on any postion
Check the control knobs, make sure they are not turned all the way on high. If not and you have ice building up on the panel below the one with the fan, you will need to go back inside where you replaced the fan and replace your defrost heaters also. It will be bast to replace the defrost thermostat while your in there. It only cost around $15.00 and will save you trouble later. You could see both of these parts behind the panel the fan is in. The heater in you model is a cal rod type, made of the same material that ele stove elements are made of. You can ohm it and if it has no resistance, it's bad. If it does then the defrost thermostat is the one bad.
Please rate solution
