Sony Handycam  HDR-UX7 Camcorder Logo
modupi motaung Posted on May 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix error c:13:02?
Once I insert recorded and new discs in my camera it displays error c:13:02 and the access light does not light
John Han
Level 2:
New Friend:
  • Expert 38 Answers
  • Posted on May 09, 2014
John Han
Expert
Level 2:
New Friend:
Answers
38
Questions
0
Helped
15405
Points
117
Blow dust in the laser pickup with an hand blower.
If there's no improvement, the disk drive unit must be replaced.
1 Related Answer
aryandeb
  • Posted on Nov 07, 2007
SOURCE: Disc Error: Remove Disc
YOU PLZ CONTACT WITH NEAREST SERVICE CENTER.
2helpful
2answers
I am getting a TOC error on the left drive with new laser.
Table of Contents errors can be the result of bad compact disk, bad laser or the head cannot get into position to read the TOC, Make sure that the new laser is aligned correctly and that the head has no obstructions at either end of the rails. Last but not least you may want to make sure the laser is working and you can check that by using a camera like the one on your cell phone, With the cover off, insert a cd in the drive and have your camera pointed at the area of the laser. You should see the laser light on your camera.
1helpful
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
Sony camcorder 'Movie recording disabled'
You need to finalize it in the camera, the one you used.
Then you should be able to access what little data if any on it.
If you can not get it to finalize then take both the camera and disk to a photo shop. They may be able to recover it for you.
Let us know the results. Good luck
Disc error on hitachi camcorder
it may be that you need to format the disc this option should be located in the menu somewhere if it does not automatically ask you when putting a new disc in the camera. i hope this helps you.
1helpful
I have Mavica CD-350. All of a sudden when I attempt to format a new disc or re-format over an old one, the format process gets to the end and then beeps with the message "format error" After...
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Please make sure that you're using either CD -R disc which does not require formatting or CD -RW disc.
If you're using any other discs like CD +RW, CD+R may arise the error message.
If the issue persists with a new different CD -R disc, service may be required for the Camera.
1helpful
MY SONY CYBER SHOR DSC-W270. IT SHOWS SYSTEM ERROR WHEN TURNED ON.
The System Error message displays when the files on the recording media have been copied or deleted repeatedly on a computer. Backup the files on your computer, then format the recording media in the camera to resolve this issue.
Formatting the Memory will erase all the data stored in the Memory Stick.
If the error message displays after formatting the Memory Stick, then try using a different Memory Stick media. Once the Memory Stick is inserted, perform manual power reset of the Camera.
To reset the Camera, turn off the Camera and remove the battery pack.
Then, allow the Camera to remain without power for 30 seconds.
Later, re-insert the Battery pack in the Camera to resolve the issue.
Thanks for using FixYa.
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
DISC ERROR
This means the the floppy disk drive has dirty the reader/recorder heads, or the heads are misaligned, or the floppy has a mechanical problem during the reading process.
You can start in blowing compressed air inside the floppy disk.
If it does not work, then the floppy drive will need to be serviced or replaced.
Best regards,
1helpful
Error message + disc opened acidentally + recording disabled
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
