Question about Cerwin Vega Stroker Pro 12 Car Speaker
Need to know where to buy a recoil kit for my stroke..its a 12" 4omh
Look up this number on ebay. 360132437291... it is a person thats advertising rebuild kits for strokers
Posted on Jun 23, 2009
10 hp Evinrude starter recoil how thick is washer under recoil spring?
Just go to an Evinrude dealer or buy that washer online. Click on the link to see the expanded schematics. Click on the ALL tab to see where to buy online. you need the exact model and give them the serial number as well.
evinrude sportwin 10 hp parts Google Search
Mar 31, 2018 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
Pull cord not grabbing
The Dogs inside the Recoil are worn or Dirty is my first idea. But it could also be a loose Recoil also (This happened to me and my Ski Doo XP.
I purchased a new Recoil just to find out that 3 of the bolts were missing. Got new bolts and tightened it up and returned the Recoil. Ski Doo's Recoil Rebuild Kits do not last very long.
Nov 12, 2013 | Polaris 2010 WideTrak 600 IQ
Bad stator on ski doo. how do i change it?
wot model is it , 2 or 4 stroke engine ? let me know as i am a marine engineer for 29 yrs and have worked on jet skis , outboards , inboards of all makes !!! P...
Oct 24, 2013 | Motorcycles
I have having problem with my Hysqvaran 125L with the pull cord. When i pulls cord, it not catching the trans and it sound like the spring is not catching?
Hi and welcome to FixYa, I am Kelly.
It sounds like the starter cup has failed / broken. See this link: (Page 3 item 14.)
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2008/HIPL2008_5450143-15.pdf
However... the pawls on the starter pulley (item 28 above) may have broken.
There is a whole kit for repairing the starter recoil: PN 545180844
That can be found here:
http://cgi.ebay.com/HUSQVARNA-RECOIL-STARTER-KIT-124L-125L-128L-545180844-/150485511147
Your need to remove the starter recoil assy and check for damage. It will be obvious. Just remove the mounting screws and lift it off. It is not difficult. Use the first link page 3 to identify the parts you may need once you do the visual inspection with the recoil removed.
Thanks for choosing FixYa,
Kelly
Apr 23, 2011 | Husqvarna 28cc Gas Line Trimmer
I have a 8900 with techusm motor and i need a recoil starter rebuild kit it is the eskimo ice auger
You cant get the rebuild kit for this anymore. You can get a bolt on recoil starter, they are about $30.00.
Go to your Tecumseh dealer, and they should have the part.
Hope this helped.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 01, 2011 | Sport & Outdoor - Others
Can't find replacement recoil kit
What engine is on your presure washer? I really need a model number to give you the correct information.
If you have the engine model number you can look the engine up on the net at:
http://jackssmallengines.com/help.cfm
and find your recoil assy.
If it is just the rope that broke you can take the recoil to any lawn mower repair shop and they will repair your recoil by replacing the needed parts or replace the rope. You do not need to take the whole unit to the lawn mower repair shop. FYI a NEW honda recoil assy ranges from $32.00 - $68.00 depending on net source.
Thanks for using FixYa.
Kelly
Apr 16, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Oil and torque question for Polaris sport 400l (aka trailblazer)
You do not put oil in the recoil housing, the drain bolt is for draining water that gets in there if you drive through water. The oil you seen could have been put in there to lube the moving parts when it was apart at a an eariler time.The bolt at the top is to to do a visual inspection for.
Apr 01, 2010 | Polaris ATV
What causes a 2 stroke engine to have too much compression and therefore difficult to pull the recoil starter?
Nothing will do this...what is most likely the problem is either the recoil is going bad or you have the wrong spark plug installed.
Dec 03, 2009 | Toro& Electric String Trimmer
Electric dryer coil overheating after DIY repair
The correct part number that we have on hand (Appliance Parts Warehouse, Sears, etc) is 5300622034.  This would be the correct element restring for this model.  Tried to find the number you have but couldnt.  If its the wrong restring kit, it will do just what its doing.  They make these just the right length for the resistance values.  I know the old GE models you had to measure them just right.  I believe that you probably have the wrong one.  Hope this works for you.  Jim
Oct 24, 2007 | Dryers
Car Audio & Video Logo
584 people viewed this question
Top Cerwin Vega Car Audio & Video Experts
Frank de Armas
Level 1 Expert
Chris Larocque
Colin Stickland
Colin Stickland
Are you a Cerwin Vega Car Audio and Video Expert? Answer questions, earn points and help others
