Question about RCA F36668 36" TV
My TV shut off and will not come on
My 36' TV shut off one night and will not come on. When I plug it in it makes a high pitch beeping noise. Can you tell me what the problem is?
  • 85 Answers
Re: My TV shut off and will not come on
This is an issue with one of your power supplys wether it be high voltage horizontal power supply or the reg power supply. The beeping noise is letting you know that it has some power but not enough to start the high voltage needed to create the picture on your tube. I would seek professional help for this issue.
Posted on Dec 11, 2007
0 characters
3 Points
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Super high pitch whistle from tv, only powering it off helps.
Shut it off and unplug. You have a serious HIGH VOLTAGE problem that could cause a fire. Professional repair needed.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
High pich whine from CT-36D32 36" TV
jdosk-the high pitch noise you hear is generally from the horizontal output being shorted,the horizontal output is usually near the flyback transformer,get a digital multimeter to checkthis part.Let me know I'll try to help. cooltek Feb.16/08
Feb 05, 2008 | Panasonic CT-36D32 36" TV
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Oct 25, 2007 | RCA F36705 36" TV
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
TV will not turn on.
A high pitched whine is most of the time the power supply trying to run, but it is being loaded down from a short somewheres in the set. Sometimes a resistor on the CRT board will open and make the set shut down right after start up, sometimes the horizontal output transistor causes this problem, almost any circuit for that matter can cause this problem. Good Luck
Jun 14, 2007 | Philips TP3681C 36" TV
High pitched whine coming from the back of the tv, inside
possible coil vibration look around the yoke plug try to isulate the noise to a section of the board the is acommon fault/if not call for service not pricy.
Dec 30, 2006 | Sony FD Trinitron WEGA KV-36FV27 36" TV
RCA F36668 36" TV Logo
181 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
