I'm replacaing the pull start as the previous one broke. I also want to change the flywheel. Not sure if it's a left hand or right hand thread, don't want to shear the bolt off!
SOURCE: 49cc mini pocket quad wont start
if it has a kill switch make sure it is on, check that you are getting spark at the plug and have the right fuel in the motor.
Remove the air filter from the carbi and squirt some 2 stroke fuel directly into the throat of the carbi and try to start it.
hope this helps
SOURCE: changing the oil
you don't half to change the oil it takes a oil fuel mixture like a chainsaw or a weed-eater
SOURCE: Small unnamed quad, prsumed 49cc, wont fire only clicks.
take of the pull starter and look at the cog and pull the rope and if the cog pops up then its fine
SOURCE: My 49cc quad bike is new wont start have changed
Maybe re-check the gap between the coil and the flywheel? x2 business cards is a good gap for those.
SOURCE: hi there just brought a
Hello
Since this is covered under warranty do NOT attempt any repairs, if you tamper with the engine in any way you will void the warranty. Return it to the company that sold it to you for repair. Based on what you say you most likely have a fuel delivery problem, it is to rich, that means the engine is getting to much fuel, this causes the engine to flood out, the other possibility is the engine has poor compression.
