Question about HP PAVILION A6230N DESKTOP PC
Computer turns off while in use after 2hrs.??? screen msg.=no sig
Computer turns off while in use after 2 hrs.???? screen mesg==no signal????
    President:
  • 3,278 Answers
I agree that the fan or heat sink is likely the problem. Feel the CPU and see if unusually warm or hot, which would indicate a fan or heat sink problem. I would also suggest checking/testing your memory modules (insert one at a time). Good luck
Posted on Jul 05, 2009
    Scholar:
  • 155 Answers
Your memory might be too low for your storage and processing. If you are encoding a word document, from every now and then you have to save it otherwise it will tip off and you'll lost your documents. Or go to control panel and look for power options set the power off to never.
Posted on Jun 22, 2009
    President:
  • 828 Answers
I think you have to check your Processor Fan is still working and the heatsink tightly connect in processor... a lot of checking if your personal computer is turns off.. the power supply it might have a problem and change it temporary then run some test on your if still turns off...
    Sergeant:
    Champion:
  • 240 Answers
This sounds like the monitor rather than the computer. Remove the plugs from monitor to comp and reinset them. Sounds like a loose cable. Do this on the back of the monitor and on the back of the pc.
How to hook up a 2 wire system to a 3 wire system, help!
The 3 wire is a running light/turn signal combo. On the three wire you have neutral, turn sig hot and running light hot.
If you want the two wire bullet light to be a turn sig, you will have to hook up the neutral/ ground and the turn sig hot. The running light hot will be capped.
If you want the bullet light to be both a turn sig and a running light you will have to buy an aftermarket product to regulate the power to the lights.
Apr 14, 2014 | 1993 Harley Davidson XLH Sportster 883...
Takes 1-2hrs to turn on
hi sound like a power supply fault, could be capacitors or dry joints
i'd look for a tech in your area hope it helps
regard
shaun
Jan 31, 2014 | LG 60PC1D 60 in. Plasma Television
My E52 Switches off if I try to open the Inbox .. I un able to open the inbox even to delete the old mesg please advise on how do I delete the mesgs regards
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jan 01, 2011 | Nokia E52 Smartphone
Screen just went GREEN in middle of a broadcast. Tried settings, & then unplugged for 2 hrs. Still green screen.
The tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com Ebay.com to buy a refurbish tv Tuner sisgnal board for the replacement.
Dec 17, 2010 | Sylvania LC420SS8 LCD TV
Brake lights do not work. step on brake in park brake lights work. turn right signal on and step on brake left brake light comes on . turn on right signal and no brake lights work. put transmission in...
One of 2 things to have checked, if all your bulbs and connections are correct. 1-stop lamp switch module.
2-multifunction/combination switch (blinker arm/components that are in the steering column). For about a 1/2 hrs. labor cost, a mechanic should be able to test the circuits.
Apr 28, 2010 | 1997 Oldsmobile Cutlass
When dubbing a homemade vhs movie to dvd it stops at 2 hours and ten minutes even before the movie has completed
If the dvd is stopping, check the recording setting as you may of set it to standard play, which is about 2hrs, set it to extended play for 3 hrs or longplay for 4 hrs and super long play for 6hrs
Apr 04, 2010 | Televison & Video
My vx2035wm starts flickering real bad after about 2 to 4 hrs of work. it only stops if i turn the screen off for 2 to 4 hrs, then it repeats. please tell me what the problem with my moniter is
Does it happen *ONLY* when connected to *YOUR* computer (implying that the video-card in your computer is failing when warm) or does it happen when connected to *ANY* computer (implying some heat-related problem inside your LCD monitor) ?
If the monitor is still under warranty, exercise the warranty to get it fixed. If the warranty has expired, it's cheaper to buy a new monitor than it would be to repair it.
Mar 03, 2010 | ViewSonic VX2035WM LCD Monitor
Monitor flashes blue light and takes a long time to come on
Disconnect monitor cable from back of the computer and see if u have a error msg on the screen > if u find a error msg like " NO VIDEO SIGNAL"> then ur monitor is fine or else ur monitor is BAD
Oct 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
When i changed my sim, i keep getting Msg in my old number
it is impossible to keep getting mesg in old sim.but u can try u have to coppy the messgae in save item ya draft.but some mesgs u can get in ur old number.u have to save mesgs nd then change ur sim
Sep 28, 2009 | Samsung S8300 Ultra Touch platinium-red...
HP PAVILION A6230N DESKTOP PC Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
