Question about Rinnai EnergySaver 556 Air Conditioner
Rinnai 556F stuck on Low and will not produce heat
My Rinnai 556F unit has worked great for several years to heat a finished attic space, but when we turned it on the other day as the weather turned cold, we encountered a problem. The room that has the unit is presently at about 60 degrees. When we turned the unit on and set the temperature to 72, the fan started running, but the heat never turned on and the "Low" light lit while the On light flashed red. Each time we turn the unit on, we get the same results. An clues?
  • bobolech Nov 13, 2007
    Thanks for the advice. My pilot light would go on for a few seconds and then turn off. There was no way to remove the sight port with my model, but I was able to get into the burner area to remove a very toasted fly carcass that was plugging/diverting the gas for the main burner. Once I flicked the fly away, everything worked great.
    Thanks!
  • 1,420 Answers
The Low code indicates that the heater did not start because of lack of gas or that the flame rod did not sense enough heat. Make sure all gas valves are on and if you use propane gas, that it has gas in the tank.
Assuming all gas is on, you will need to remove the front cover by first pulling off the very bottom trim piece. This is located below the louvers and by grasping both left and right sides of this trim, pull toward you. It is just held in place by little clips. Now taking a very new #2 Philips head screwdriver, remove 2 screws found on the extreme left louvered section of the front. Then 2 more on the extreme right. Two more near the center of the louvers. Now I think there are two more holding the bottom in. Gently move back and forth the front panel starting at the bottom and work out the clips at the top just below the instrument area. Be careful to not break any of the clips at the top. With the front off, at about the 5 o'clock position you will see a very small round hole with glass over it. Start the heater and look to see if it ignites and stays on for a second or two. If it does but goes out very quickly, you may have a corroded flame sensor. The flame sensor is located by looking into the small hole and up to the 11 o'clock position. All it is is a probe that sticks down. The only way to get to it is by removing the small window section of the heater and use a wire brush used to clean a gun and brush it. Or very gently take a thin but long regular screwdriver and scrape off the probe. Be careful not to damage the fragile white gasket when taking off the sight port.
If the heater never started, you have a restriction in the gas train. Typically I find that spiders make a nest inside the gas burner because the bugs they eat likes the gas smell. The only way to get to their web is to remove the burner from the unit and clean it. This is not an easy part to remove and suggest you call a technician.
Good Luck!
Posted on Nov 04, 2007
Rinnai DV Propain Heater 556F
Sounds like the relay might be going bad and needs to be replaced
Apr 10, 2008 | Rinnai EnergySaver 556 Air Conditioner
I have a Rinnai 556F Heater and I set it to a specific Temperature and a temperature higher is always flashing. What is wrong?
The temp you are looking at may be an error code. 72 Room sensor, 68 Over heat, 76.80 Room sensor short, etc. What is the exact code??
Tom
Oct 14, 2010 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
Do rinnai heaters run efficiently if turned up and down often?
Maintaining the lowest acceptable setting and leaving it at that temperature is the most economical way to run the unit. If the space is going to be unoccupied for an extended time (several hours), lower temperatures are okay. This minimizes the need to burst the heat to warm the space quicker. As I understand your unit, it minimizes electrical & gas consumption by basing the need on the temperature difference of actual space temperature and setpoint. The larger the gap, the more power and gas is consumed.
In summary, when the space is occupied, maintain a consistent temperature setting. When the space is unoccupied, maintain a lower setpoint.
Hope this helps. Good Luck. :-)
Feb 15, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai heating system 556F that shut off by itself and the lights start blinking. when I start it again it will start right away but it won't last long till it shut off again (1.5 hours). any...
This unit has a diagnostic error code recorder. To play back your error codes, with the unit off, push the up arrow, down arrow and economy button all at the same time and hold for 3 seconds. Record each number that lights up. In your owners manual or on rinnai.us there is a error code guide that may help. Or post the error codes on Fixya and I can give you some pointers.
Jan 27, 2010 | Honeywell Heating & Cooling
Rinnai 556F Not Exactly and "Energy Saver"...
Raise the thermistor. It is a black rubber probe located on the back of the heater close to the coldest spot in your home, the floor. Raise it a few inches. To do this you will need to unhook it from its holder and open the front of the heater to unravel the extra length of yellow wire.
Jan 24, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
I have a Rinnai Energysaver 556F
The heater will have some error codes stored in it. To retrieve them get an assistant to write down the codes as you see them. They come quickly. OK to get the codes, push down on the Economy button and the up arrow and down arrow at the same time. Hold for three seconds. It will take three fingers to do this. Once you get the error codes, look in your owners manual to diagnose.
Nov 21, 2008 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rinnai 556
money seems to be an issue for lots of us. but if you don't mind a coupla extra bucks get a few axial muffin fans and use them to spread out the heat pattern at your bedroom doors
Jan 18, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai EnergySaver 556F Heater flashes
I'm picking up a faint propane scent when the heater is completely turned off. When I turn the heater on it lights fine so I don't suspect it's the pilot light. Is this an issue with the installation of the fuel line, or could it still be the pilot? Any ideas on troubleshooting the source?
Nov 10, 2007 | Rinnai EnergySaver 556 Air Conditioner
Rinnai EnergySaver 556 Air Conditioner Logo
447 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
