Question about Troy Bilt Tb70ss Gas Trimmer
Weed eater will idle but shutdown upon giving gas
My troy built weedeater has run fine but all of a sudden it quit. I can crank it, and it will idle, as soon as I give it gas it shuts down. I have tried cleaning the carb, and screen on the muffler but still no luck. any suggestions, oh yea if I need parts, where do I get them??
HOW TO HOOK GAS LINES UP TO CARB AN GASS TANK
Posted on Apr 16, 2011
    Scholar:
  • 81 Answers
Cleaning the screen on the muffler will help but the muffler itself is what needs burned out. This can be done with a fire or a torch. Let the muffler cool on it's own as use of water can warp it. Parts can usually be purchased at any small engine repair shop that represents Mtd. That's who make the weed eater.
Posted on Jun 22, 2009
How to restring the weed eater head on the Troy built gas weedeater
Unscrew the bump knob. Remove spool and wind line in direction of arrow on hub.
Jul 01, 2018 | Troy Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ prerunnerrngr@yahoo.com and i will point them out
Jul 13, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt Tb70ss Gas Trimmer Logo
1,615 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
