Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Pressure gauge at maximum
I have an Hayward vari-flo. When on Filter, the pressure gauge is always at maximum, but when on backwash, the pressure gauge is a couple of lines lower than maximum.
  • XPoolGuy
    XPoolGuy May 11, 2010
    How is the water pressure coming back into the pool? Is the water pressure strong?
  • John Prohaska
    John Prohaska May 11, 2010
    When you turn off the pump, does the gauge return to zero? What is the maximum on the gauge? Perhaps you just need a new gauge that goes up to 45 or 60 psi.
  • 110 Answers
Do you have a 'Earth' (dirt) filter system.
If - yes - these get block v-quickly (v-quickly!)
* Try to minamize 'vac'ing your pool, (or clean filter each time after 'vac'ing Or Vac on waste setting)
* Use pool skimmer box filter socks.
Posted on Jul 07, 2009
Hayward vari flo valve
Does it filter? Does the pump have full prime? I'm not clear about how when the valve is put in the backwash position nothing happens.
Jun 15, 2013 | Pool & Spa
Hayward sand filter
Reference your pressure gauge as the 12:00 position. Going clockwise-
12:00 is Filter, normal running position
2:00 is Waste, water goes from pool and exits the waste line, bypassing filter.
4:00 is Closed, used only when servicing equipment
6:00 is Backwash, reverses water through the filter and goes out the waste line.
8:00 is Recirculate, water bypasses filter and returns to pool.
10:00 is Rinse, water goes through filter and exits to waste line, used briefly after backwashing to clear sediment from filter.
Note that the "pointer," not the handle that you grab, indicates which setting you are on.
May 19, 2013 | Pool & Spa
What i she sequence when backwashing---Backwash - Rinse - Wash ? I have a Vari Flo
Backwash until water in the sight glass is clear, shut off the pump and change the valve setting to rinse, turn the pump on for a couple seconds and then back off, change the valve setting to filter and return to normal operation. NEVER move the valve handle while the pump is on.
John
May 05, 2011 | Hayward SAND FILTER, PRO SERIES
Too much pressure in sand filter
IF your filter is really the EC75 that's listed in the heading, then it's not a sand filter, its a DE filter. See link to manual:
http://www.haywardnet.com/products/Manuals/pdfs/Manual257.pdf
If this is not the correct number, then you can find the correct manual on their web site. So did it have a multi-port valve already? or did you install it. IF it is a sand filter then there is something plugged inside the filter (small fingers on spider?) If that's the case locate the manual on their web site and follow the assembly insturcitons.
Jul 20, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Aug 04, 2009 | Hayward SAND FILTER, PRO SERIES
Recommend backflush pressure of a hayward pool filter
After you have backwashed your filter until the site glass run clear. Go to rinse mode for 30 seconds. Make note of the filter pressure. Don't backwash until the pressure goes up 10 psi!! It is important not to backwash too much. As pressure climbs the sand filter actually filters better.
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
If the spider gasket in the vari-flo valve is no good, you will usually notice one of two problems.
1. Water leaking out backwash port while filter is operating.
2. Valve positions are really difficult to change.
The way to check this is if you are able to move one or two of the "spokes" in the gasket freely(out of the track it sits in) once the top of the valve is removed.
If so you need to replace. The gasket is usually held in with a silicone sealant. Once you remove the old gasket. You will need to scrape any remaining rubber from the track it sits in. I've found that a brass brush from a pluming supply store or home depot along with a flat head screwdriver is usually enough to do the removal.
I always used Permatex Blue RTV sealant on all valve jobs. It can be found at any auto parts store or sometimes Walmart. Follow the instructions for curing. Once cured the gasket is good as new.
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Pool sand filter noisy only on filter setting and no pressure , but if you bypass the filter the noise goes away and there is pressure
Something is stopping your water flo before the filter otherwise you would show pressure on the filter guage. The only thing that I can think of would be if you had taken your backwash valve apart and reassembled it in the wrong position. Ether put the handle on backwards or mounted the top out of place. Hope this helps, good luck.
Jun 16, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
May 10, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
270 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
