Question about Canon BubbleJet i560 InkJet Printer
Canon i560 not printing, status light flashes 4 amber 1 green
Canon i560 will not print. The status light flashes in sequence of 4 amber / 1 green / pause / 4 amber / 1 green / pause / .... Appreciate any help!
    President:
  • 2,306 Answers
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Posted on Jun 22, 2009
SOURCE:
Amber and green light keep flashing back and forth, not printing. I tried rebooting, nothing happens
Switch off the printer and disconnect from the power supply. Leave for 10 minutes and then try powering up again from cold. If you are still getting flashing lights please count the number of each flash and repost
http://www.retrevo.com/pdf/262dj183/24/Handling+Error+Messages#q=Canon+i560
Mar 01, 2011 | Canon BubbleJet i560 InkJet Printer
Flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
May 10, 2010 | Canon BubbleJet i560 InkJet Printer
When I turn the printer on getting ready to print the light flashes between green and amber. When I push the Resume button nothing happens. When I turn the printer off and then turn it on again. The same...
o.k.
-check for paper jam
-check your ink cartridge
-unplug your printer for 1 minute
-turn it back on
-if same problem still exist go to your computer and look in the system tray in the bottom right-hand corner find a printer icon and cancel all print jobs.
in most cases things should function again.
Mar 26, 2010 | Canon BubbleJet i560 InkJet Printer
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Printer status screen is red and will not print Canon i560 Inkjet
You need to count the number of flashes, usually long green then a certain number of flashes, sometimes alternating red and green flashes. I need to know the number of flashes to tell you what the error is.
Jun 18, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print
The green light snable, no flashes.But test-print page is empty. All cartridges are full. Print head was reinstalled.
Sep 14, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
1. Turn off printer
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
I560
If you are lucky clean the contacts on print head or change the waste ink absorber may solve the problem , if not you need to change the print head , part code:QY6-0064 or QY6-0042, about 38 $ on Ebay.
Here is also the manual reset procedure for I560 (and other Canon printers ):
1. Start with the printer OFF
3. release RESUME
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function :
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2007 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
643 people viewed this question
Clive
Clive
old marine
old marine
