Question about Homelite Garden
Is there a trick to attaching the rewind spring to the pulley?
My dad gave me the chain saw and said the cord won't rewind. The spring is still there with a small loop on the end. The plastic pulley is in good shape. I don't see anything broken, but the pulley won't grap the spring. What attaches the spring to the pulley? The screw and washer in the center of the pulley don't do it. Thanks for any assistance.
  • 2,176 Answers
On the end of the spring there would be a loop or some other manner to attach to the pulley. Usually what you have to do it wind the spring tight (not to breaking point) and then put the loop into a slot in the pulley and push down while inserting the screw and washer to hold it in place
Posted on Jun 22, 2009
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
What's the trick to installing a flat coil spring into a chain saw recoiler without having it spring out
If you are having to recoil the spring after its come out. Roll it tightly with your hands then use vise grips on one side pinching it together then you can place it in the retainer/pulley. release
Oct 18, 2012 | Craftsman sears 18" Chain Saw Chain (...
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
Starter rewinder repair How do I rewind the starter rewinder?
If both ends of the spring are still attached, then turn the spool CCW (remove the cord first) until it is fairly wound, but still be able to turn 5 or 6 turns more to allow for the movement required when starting. The spring must not bind-up during starting. Wedge the spool so that it can't unwind again, and fix the cord to the spool inner attachment (melt the cord end before tying the overhand knot). Thread the cord CCW until the spool is nearly full, then feed it out of the cord port and slide the handle on. Melt the end and tie an overhand knot to retain the pull handle. Release the spool wedge and try the cord action--it should come out about 3' or so without binding and return smoothly. Remount the entire assembly and make sure the engine is being properly turned. Hope this helps!
Jul 12, 2010 | Poulan Pro Chain Saw 46cc 20"
The pull cord froze up. I tried to take it apart and rewind the coil spring but can't figure out how it attaches back to the pull cord housing to retract the pull cord. Any help with pictures would be...
I'm afraid you put yourself in a corner. You need to take your chain saw to a repair facility. Make sure to gather all the parts to go with. I know how to install a coil spring, but it's something you have to be shown in person how to do it. It can be pretty tricky.
You could be hurt by the spring uncoiling by accident.
Incidentally, I doubt if the coil was the original problem.
Why do you think that is the problem?
Jim Hart
Jun 20, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you rewind the starter spring / cordand wheel back into the saw housing?
wind the spring in your hand to a size that will fit back in the housing then fit it. then fit the pulley back making sure the spring fits in the slot for it.
you should then botl the pulley back in place.
to tention spring you shuld notice a notch in the pulley that is for the rope to sit in while you turn the pulley to re tention it
Apr 03, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
I'm having problems with reattaching the pull cord. I've made several attempts but the cord will not keep it's coil. What gives?
Morethan likely you have bent the end of the rewind spring and it will not hold onto the cam on the starter pulley. Since the pulley is plastic, the pulley could also be the problem.
Sep 20, 2009 | Poulan Pro Chain Saw 46cc 20"
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
111 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
