Many are unable to help a neighbor or gain anything since post are not showing up. They state Facebook is showing only 7% of the gaming post and that 'liking' and writing 'yes' will improve dramatically the issue.......hoax or the truth?
SOURCE: Facebook wont let me play Farmville anymore.
Most likely you accidently blocked the Farmville application. To check if it's blocked, click your account settings in the upper right corner. Then go to Privacy Settings, and choose Applications and Websites. From there open the list of Blocked Applications. If Farmville is there, click remove and the block will be lifted and you will be farming once again.
SOURCE: WILL FARMVILLE FIX THE PROBLEM?
The page you requested was not found.
You may have clicked an expired link or mistyped the address. Some web addresses are case sensitive.
SOURCE: Why is there an error
repair ur registry with reginout clener
install .net frame work. install active x control updates
SOURCE: Hi I play farmtown I
No need to get worried because its a facebook problem. This problem occurs sometime (but not for every one at a time). This error is like 'invalid password' error in yahoo mail even if we type the correct password.
Better to wait until face book solves it itself or if you really want to contact the customer support regarding this issue click on this link http://www.facebook.com/note.php?note_id=410099297768 to get assisted by a facebook tech. Good Luck.
Hope this helps.
Please leave a comment and rate if this solution was helpful, thanks!
