Question about Kenmore Dryers
Whirlpool gas dryer lgn 2000 kq1 gas will light for the first 2-3 cycles then just the igniter only
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
My Whirlpool clean touch 7 cycle 4 temperature gas dryer is not igniting?
then there is problem in the power circuit sir
Apr 01, 2008 | Dryers
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool gas dryer will not cycle through on Automatic Dry. When I start the dryer it will ignite and heat up, but then after it cools, it will not ignite again and therefore will not cycle. I have...
The burner valve coils (2 in a kit) need replaced . After electricity goes thru them , they will warm up , causing one of them to "open" (short internally). It will not work again till the coil cools back down . Only 2 screws hold the coil bracket on , so , they are not hard to change .Don't have to turn the gas off but do unplug dryer . The burner valve is located in the front of the dryer by removing the front panel .
Jul 23, 2009 | Whirlpool Dryers
Gas dryer , Flame cycles on and off a few times then ignigter glows but flame does not light
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 16, 2009 | Whirlpool LER4634J Electric Dryer
Dryer has gas smell, whirlpool lgn 2000w gas dryer
Hello Tuna59,
I would strongly encourage you to identify the source of the gas leak as soon as possible. To do this, you can buy a product at most home depot or lowes department stores called SNOOP.. It is in essence..soapy water with a dauber in the cap. You use it by dunking the dauber in the solution and then putting the solution over gas piping joints. If it bubbles up at all..chances are that is where you have a small leak. You may or may not want to tackle that repair yourself since it poses personal risk if you don't know what you are doing. A build up of gas vapor in a confined space is very very dangerous and only needs a small ignition source to explode so please be careful. Probably a good idea to do all your troubleshooting ( if you decide to do this on your own ) with the windows open in that area. Do not use a fan or any other ignition source to move air/gas. Be careful.. and good luck...
Regards,
Rick
Nov 24, 2008 | Kenmore 63942 Dryer
FAILS TO IGNITE ,UNPLUG &REPLUG AND WE HAVE IGNITION
suspect coils on gas valve they will breakdown after several ignitions and not open valve for burner to light
Nov 18, 2008 | Whirlpool LER7646E Dryer
Whirlpool Gas dryer ignites when I first turn it on and gets hot but won't stay hot or ignite again.
replace the 2 coils on gas valve after warm up they fail to open valve to reignite burner
Nov 03, 2008 | Whirlpool LGQ8611L Gas Dryer
Initial gas burn does not reignite
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
Hope this may help;
DON'T FORGET TO RATE;
Jul 26, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
151 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
