Question about Kenmore Washing Machines
I have a Kenmotre elite H3T washer and the washer
I have a Kenmore elite H3T washer and the washer is now not draining out and making a loud noise. It eventially ends up with lights blinking it the pump gone bad? I have already cleaned out the pump filter and still ahving issues.
  • 2 more comments
  • 3sdik Jun 22, 2009
    I very handy can you advise to narrow down the issue? Once again it stops at the cycle drain and spin and lights blink. Then I tried to run the drain cycle manually and when it starts very noisy kid of a rattling kind of sound?
    The so called expert didn't even try to work me through the problem.
    Thanks,
    I have already taken the pump out and unsreqwed it from the filter housing to inspect it but I see no propeller damage. By eliminating that what do you think I should check now?
    I think you are correct I will just replace the pump. I just ran it again and it is making a clicking noise. You have been helpful thanks fro the advise.
  • 6,784 Answers
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed. When the impeller is broken or, misaligned, it will make loud noises during the draining. I am most certain that this is a damaged pump impeller.
Posted on Jun 22, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Jun 22, 2009
    Unfortunately, you cannot repair the impeller. this is a fixed device and, you will need to replace the entire pump.
  • Michael Masters
    If the noise you stated is , indeed, coming from the drain pump, there is no other issue. you have checked the drain hoses and, filter. there are no obstructions as you stated. the only logical problem here is the pump. either the pump drive shaft or pulley is frozen or, the impeller is damaged. I'm not sure if the pump is housed in a clear compartment but, in most cases, you will need ot replace this pump.
    If the noise you hear originates from this device, you can bet the bank that it is damaged. There are no other parts that control the draining. its just a pump that is connected to a couple of hoses and excape device. check the outside drain hose. unscrew it form the back side of the unit and, take a look inside the outlet hole.
  • Michael Masters
    If possible, i could use the complete model number. i would like to pull some schematics to help further troubleshoot.
  • 508 Answers
Waterpump maybe bad or belt maybe bad? good luck
Posted on Jun 21, 2009
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Washer makes loud noise when draining
check and clean the pump. possible coins in it
Feb 07, 2010 | Washing Machines
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
Makes loud noise during the spin cycle.
no loud noises water will drain, just belt broke plastic piece needs to come off so I can replace belt.
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore h3t washer is showing codes f and sud
Hi!!! it seems that you have something wrong with your drain pump check your drain pump and make sure something did not get stuck inside also in all front loads some water does remain in the sump area .I know that trust me..pure some vinegar in around a cup and put it in a normal hoe cycle ..Good luck..
Jan 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
