Question about MegaVision MV-171 Monitor
Blank monitor when turning on computer
When I turn on my computer, the monitor is blank but the green light is on. When I turn the monitor off and then back on it works fine but it is annoying to have to do this everytime I turn the computer on. Any suggestions on what the problem is. My monitor is about 4 years old and this problem just started a couple of months ago.
  • Anonymous Nov 03, 2007
    Monitor blanks after turning on. Tekbright 510v
Acer AL2216W's green light goes off completely when the computer is turned on. When I turn on the computer and monitor, there is green light on on/off button while an irritating Acer logo is showing up....
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 13, 2010 | Acer AL2216W LCD Monitor
Monitor light flashes green and screen is blank
Best thing to do, hook up another known working monitor to the computer and this will verify that the computer is working properly.
If you get video on the known working monitor when you turn on the computer then you know the computer has a problem.
Aug 27, 2009 | Computers & Internet
Model HU171D Hanns.G... Monitor is on but blank screen appears...
I think the data wire may be disjoined in the Center. try to replace the data cable and reply me.
Aug 19, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Viewsonic Optiquest Q19 blanks out - just a year old
Sounds like the LCD panel inverter is going out, if not gone out completely.
Jul 18, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
MegaVision MV-171 Monitor Logo
Top MegaVision Computers & Internet Experts
David Payne
David Payne
Are you a MegaVision Computer and Internet Expert? Answer questions, earn points and help others
