Question about Goodman CLJ30AR32 Air Conditioner
My goodman heat pump will not go to aux heat from the thermostate manual, did i wire the thermostate wrong
  • barger4 Jun 23, 2009
    it is a heat pump stat, did i leave a jumper wire off
    Sergeant:
  • 340 Answers
Yes. or not a heat pump t-stat
Posted on Jun 22, 2009
  • taa43 Jun 23, 2009
    its not wired right would like a better ratting. Thanks Tom
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
I HAVE A GOODMAN HEAT PUMP, MODEL AR30-1. I switched off the heat pump at the stat and the elements seem to be running heating up the unit... Also what is the brown wire coming from the wiring harness for...
The brown wire on a Goodman is tipically for the emergency heat option on your heat pump. First thing I would check is making sure it is wited correctly. Verify your stat is heat pump capable. Many of the cheaper stats only work for ac or just a heat pump. Anything beyond that would be a more serious electrical problem and should be looked at by someone with the proper training and tools.
Feb 11, 2011 | Goodman Heating & Cooling
Very cold outside should we swithc to aux heat to be more effice
I recommend running the heat pump even in the cold weather. If you like you could turn to EM heat around 10 degrees, but you do not have to. The newer heat pumps seem to work better than the old ones did in the colder weather.
Jan 04, 2010 | Goodman CLJ30AR32 Air Conditioner
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
My Aux heat seems to run all the time.
Is it cold enough in your area to lock out the heat pump?If the heat pump isnt operating correctly the aux heat will come on then too.
Jan 04, 2009 | Goodman PHKJ048-1 Air Conditioner
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Wiring diagam for goodman heatpump and air handler to thermostate
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Oct 09, 2008 | Goodman Heating & Cooling
Goodman CLJ30AR32 Air Conditioner Logo
177 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
