Question about Compaq Armada E500 Notebook
Turned on our Compaq E500 laptop and the black color in the screen has disappeared and red has become dominant. Now mostly all shades of red and blue. Can this be dealt with? Thank you.
    Scholar:
  • 155 Answers
Open Display properties in Control Panel.
Click Settings tab, click Advanced and then click adapter tab.
Click Properties, Click the driver tab, and then click the Update Driver.
Click the Install software automatically (Recommended).
Follow the instructions in the Hardware Update Wizard to search for a better display adapter driver.
Restart your computer if you are prompted to do so.
Go back to Desktop settings by placing the mouse on the desktop and click right, then scroll down to Properties. Click settings and then adjust color of your computer to how many bit.
Posted on Jun 22, 2009
  • 11 Answers
Sounds like the screen inverter is going bad on you. Call a pc repair shop for information on repair.
Posted on Jun 21, 2009
Rca d52120 need more green and red color
sounds like the Blue CRT drive has an issue which causes the blue to become dominate thereby limiting the red and Green CRTs from projecting normally. Is your screen full of blue?
May 23, 2011 | RCA D52120 52" Rear Projection Television
Can i put pc133 in a compaq armada e500,it turns on but nothing on screen
you can put on compaq e500, because e500 Pentium 3 and use DIMM PC133, but not show on screen you must sure your DIMM no broken.
Apr 08, 2011 | Compaq Armada E500 Notebook
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
the is some loos connection in the staip comming from lcd to motherboard.
check it.
Nov 24, 2008 | Computers & Internet
No DISPLAY ON THE SCREEN
If the external display works fine then the most common fault is the Inverter board for the LCD. By having the external display function properly, the video signal from the video graphics card is working.
The other fault could be, but generally isn't, the TAB welds on the LCD. Usually when these go a portion of the display will be lost first or discoloration e.g. red/white/or black stripe appears.
I generally don't include the CCFL (Cold Cathode Florescent Lamps) as a fault as the inverter is what supplies the voltage to the lamps.
May 26, 2008 | Compaq Armada E500 Notebook
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
Black screen
I'd reseat the memory first. If there are two pieces, take first one, then the other alone in the system. Possibly bad memory. If that's not it, the lcd cable could be unplugged. Try connecting to an external monitor. If that works, it's the lcd somewhere.
Good luck
Nov 22, 2007 | Compaq Armada E500 Notebook
SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Compaq Armada E500 Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
