Question about Philips Magnavox Learning Universal Remote
Just had a scientific atlantic explorer 8300 installed by blue ridge cable and now my dvd player philips magnavox dvp3962 player plays but i cant get the picture on the tv. I have a synergy v rt-u64cp-55f remote and i cant find a way to go from cable to video source.
Call Blue Ridge and get new remote then have tech program all buttons before he leave at no charge!
Posted on Aug 19, 2009
Philips dvp3962/37 turns on and off
the problem is may be at the main Capcitor in the power supply. if not try the relay. pls do inform me if this works ...
Jul 03, 2012 | Philips DVP3962 DVD Player
I have a Magnavox MWR20V6 and when I play a DVD it is only in black and white
Check your cables. Make sure the green, red, & blue, are in the correct order into the female connections on the back of your tv.
Nov 20, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cant hook up magnavox dvd player to t.v.
i hope the dvd player has the RCA cables for connecting the input signals to the tv for display and sound. the cables have input jacks at its ends and the same are color coded for easy identification on where to plug it in. with the use of colour insert the yellow pin to the tv yellow input and the same to the dvd and do the same to the white and red terminal and proceed on by turning the channel to AV and play
Sep 27, 2011 | Philips Magnavox DVD/VCR Dual Player
How do i deactivate the password on a philips dvp3962
Try using your remote, access the general setup menu and choose the Disc Unlock option.
Hope this helps!!
Mar 01, 2010 | Philips DVP3962 DVD Player
Philips DVP3962 dvd player not showing picture when play dvd but can hear music. Sound is going through receiver and video hooked up to go through tv.
I put A dvd in my phillips dvd player dvp 5140 player and it say put in a password i never put a password in it how can i get rid of it
Dec 28, 2009 | Philips DVP3962 DVD Player
The colors are wrong on the screen. everything is orange and green and pink. just started after 6 months of perfect play. changed hdmi cord and port and that didn't help. it may be from overheating, but is...
Not a solution, but this will still allow you to watch DVDs until you carefully research customer feedback on DVD players. (Which I didn't do when I bought my DVP3962!)
That happened to me after 6 months. I used the A/V cables, then after a week or so I tried HDMI again. It worked for another 5 months, and is now crazy colors again.
Nov 15, 2009 | Philips DVP3962 DVD Player
Lost manual, can't get VCR to play
There are several Philips and Magnavox DVD/VCR combos that have sepearate video connectors for the DVD and VCR side. Double-check the yellow composite cable that is plugged into the back of your Magnavox - it should be plugged into an area that says either "DVD/VCR" or "VCR". If you are currently using red, green, and blue video cables, you will need to add a second video cable - a yellow composite would be easiest. The reason for this change is that red/green/blue cables will only operate the DVD side on most Philips/Magnavox players - that is just the way they decided to design them. If you happen to find a model number listed on the back of your combo unit, and have the model number of your television, I can take a second look at it, and tell you exactly which connections to make. Good luck!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
I need help! Our cable jack on our tv is messed up so we have to run it through a dvd/vhs player. I have tried everything to get it to work. I can play dvds and see them, but i cant get the satellite to...
Change the source on the Philips/Magnavox to switch between satellite and movies (warning: this particular Philips/Mag cannot process HD Satellite receiver boxes). You can switch sources by using the Magnavox remote and pressing 0-2. Then press ch down until the display says either L1 or L2 - whichever input the satellite is connected to. Another warning: For my instructions to work, you must have a non-HD satellite receiver, and you must run a red, white and yellow cable from the satellite box to the Magnavox instead of a standard coaxial cable wire (and then, of course, run a second set of red, white and yellow cables from the Magnavox to your TV).
-Tha Mp3 Doctor
Dec 31, 2008 | Philips Magnavox DVD/VCR Dual Player
HDMI->DVI cable won't work
Get another cable box, the scientific atlanta are notorios for these type of problems
Mar 26, 2007 | iLO 2600 Television
Philips Magnavox Learning Universal Remote Logo
744 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
