Dell W3706MC 37 in. LCD HDTV Logo
A
Anonymous Posted on May 03, 2014
How to turn off parental control activation if I have forgotten my code?
I set parental controls on my Sony OLED TV.
Master Code and Reset
Reset your Sony TV PIN
  1. Press the HOME button.
  2. Scroll down to Settings.
  3. In the Personal section select Parental Lock (Broadcast)
  4. Enter the Master PIN (9999)
  5. Select Change PIN Code and change it to your desired PIN.
Reset your Sony TV PIN - YouView Support
YouView Support https://support.youview.com > parental-controls-and-pin
How do I set a PIN code for my TV or cancel ...
Sony https://www.sony.com > electronics > support > articles
Parental lock · Select System ? Parental controls ? Change PIN. · Select Watching TV ? Parental controls ? PIN Code. · Select Device Preferences ? Parental ...
I forgot childlock password in panasonic tv c400
http://eng.faq.panasonic.com/app/answers/detail/a_id/10865/~/how-do-i-reset-the-pin-code-for-parental-control-use-if-i-have-forgotten-it%3F
Online chat for support.
Instructions show above:
How do I reset the PIN code for parental control use if I have forgotten it? Please follow the steps below:-
  • Power the unit on.
  • Open the unit's drawer.
  • Select the BD drive with the Drive Select button.
  • Press and hold the REC and PLAY buttons on the front of the unit together for 5 seconds until the display shows INIT.
  • Confirm that the front display shows 'INIT'.
  • The parental PIN code has now been reset to the default code of '0000'.
I downloaded fxnow on the XBox 360 andmy Samsung s7 activated it changed the parental controls and it didn't unblock any movies
  1. Parental Controls on Xbox 360:
    • Check the Xbox 360 parental control settings. These settings can restrict access to content based on content ratings. Make sure they are set to an appropriate level for your preferences.
    • If you've forgotten your Xbox 360 parental control passcode, you might need to reset it. You can do this through your Microsoft account or contact Xbox support for assistance.
  2. Activation on Samsung S7:
    • If activating the FXNOW app on your Samsung S7 has changed the parental controls, check the settings within the app to make sure you have set the appropriate level of parental controls. There should be an option to customize these settings within the FXNOW app itself.
  3. Unblocking Movies:
    • If you're having trouble unblocking movies, it may be related to the parental control settings within the app. Adjust the settings to allow access to the desired content.
  4. Account Syncing: Ensure that you are using the same FXNOW account on both your Xbox 360 and Samsung S7. Sometimes, parental control settings are associated with your account, so if you're logged into different accounts on the two devices, it might cause discrepancies.
  5. Contact FXNOW Support: If the issue persists, it's a good idea to reach out to FXNOW support for specific assistance related to their app and parental control settings. They can guide you on how to set up the controls to suit your preferences.
By adjusting the parental control settings on your Xbox 360 and within the FXNOW app on your Samsung S7, you should be able to customize the access to content and resolve any issues with blocked movies. If you continue to experience difficulties, contacting FXNOW support for further assistance is advisable.
3helpful
I am the forgetful parent and need to reset the
1. Turn on your Wii console and go into the Wii Options Menu
2. Click on Wii Settings and click the right arrow until you see “Parental Controls”
3. Say “Yes” to “Change Parental Controls?”
4. Click on “I forgot” when it asks you to enter your pin
5. It will ask you for your secret question, click on “I forgot” again
6. The screen will read “If you have forgotten both your PIN and secret question, call the consumer service number listed in the Wii Operations Manual and provide the confirmation number below. You will be issued a master key.”
7. Call Nintendo at 1-800-255-3700 and give them the confirmation code listed on the screen. They will give you a new Master key to enter on the next screen.
8. The PIN is now reset/disabled
3helpful
Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
4helpful
2answers
How do you reset forgotten parental control password?
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
6helpful
2answers
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
2helpful
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
2answers
Does xbox have a parental controls?
Violence, sexuality, and all-around bad behavior abound in many Xbox games. That can be fun for adults but scary for children. Here's how to activate built-in parental control features. Turn on the Xbox console without a disc in the disc tray. From the dashboard display, choose Settings > Parental Controls. Select Pass Code and press buttons on the controller in any sequence. Remember what buttons you pressed and the order in which you pressed them. Select Games and choose the maximum rating level you want to allow. Xbox will also allow you to set maximum rating levels for DVD movies.
Top Dell Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Paul Bade
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
