Question about Canon Office Equipment & Supplies
My canon i680 printer not printing in black. I've
My canon i680 printer not printing in black. I've replaced ink cartridge and still not working
SOURCE: Printer will not print black, but will not let me replace black cartridge
Had the same problem but this worked for me. To force a cartridge change, press and hold down the PAPER FEED button for at least 5 seconds as suggested here:
http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=313630&data=qBjAbS6NcI3fNMgp8+fHGGs5vImpFwyM
I then changed the black cartridge, even though I hadn't used much ink from the old cartridge and the computer was showing it as three quarters full.
Posted on Apr 22, 2008
uten
  • 162 Answers
SOURCE: new cartridge won't print
re-seat the black cartidge, do head cleaning, get a windows test page (go to printers and faxes then right click on the printer icon and choose properties, click the print test page button).
replacing ink cart is the next step or service.
Posted on Nov 26, 2008
  • 739 Answers
SOURCE: Canon MP600 printer. Black Ink cartridge PGBK5 is
You need both. One is pigment and the other is dye. One is used for photographs and the other for non-photographs - but it's the printer that decides which one to use.
All Canon printers (to my knowledge) will stop working if any one ink cartridge is empty. This is to prevent damage to the print nozzles. The ink itself is the cooling medium for the hot nozzles.
Posted on Nov 29, 2009
Testimonial: "Instant answer so I can stop trawling the internet now! Thanks"
  • 1606 Answers
SOURCE: The black ink won't print on my canon iP5200.
Try removing the cartridge and cleaning the cartridge contacts in the printer with a cotton swab dampened with isopropyl alcohol. When the contacts are dry, lightly scrub them with a white pencil eraser (the red ones are too coarse and may cause more problems), then wipe clean with a dry cotton swab.
If that doesn't help, open up the printer and find the other end of the ribbon cable connected to the print head carrier. There is often some sort of locking clamp on that connector. Unlock it, pull out the ribbon cable and clean the contacts on that end, then reassemble. (The lock may be a sliding sleeve around the cable (it only comes out about a millimeter) or a flip-up plate. If there is nothing like that, the cable is a friction fit and pulls out with a small amount of force. Some very cheap printers use a permanently attached connection).
Explanation: It is possible that there is a second drive voltage to the print heads that isn't connecting, but its failure doesn't prevent normal communications to the cartridge using the logic level voltage.
Posted on Dec 09, 2009
SOURCE: Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
Posted on Apr 03, 2010
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
Canon Pixma MX300 won't print black anymore! How to fix?
I have used "refill" kits in the past and for the time and effort involved you might just try finding a local retailer that will give you credit for the empty cartridge to replace with a professionally refilled one.
The problem with refilling the same cartridge over and over again is that they will, eventually, need to be replaced. I would suggest that you
1 - Make sure there is nothing plugging the hole at the top of the cartridge to allow air in, which is needed to let the ink flow out.
2- Install another cartridge and you get the same problem, then it narrows your fix to something with the printer.
3 - If it is the printer, I were rubber gloves and use "denatured alcohol" and a rag (no not use anything with paper as it can tear and leave pieces inside causing the printer to jamb) and after removing all of the cartridges wipe down anything that I can reach inside the printer.
4 - Although you have tried the DEEP CLEAN, if the none of the above works for you, try the NOZZLE CLEAN. If you are still having a problem then either re-post the problem or doe a Google Search listing the model of the printer you have, you may find out it is a problem that others have experienced and there is no solution.
Good Luck
Apr 06, 2013 | Canon PIXMA MX300 All-in-One Printer
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
I've got a HP C4780 printer which I have had for around a year but only used about 5 or 6 times! Despite the ink cartridges having ink in them, the black cartridge is not printing at all. Not even a...
The ink solidifies right behind the micro printing nozzles. The only way to attempt to rectify this is to dip the print face into some warm (not hot) water for a minute or two, and dry after wards. If the cartridge recovers, Yippee, if it doesn't, replace.
Common problem. Be thankful it isn't a Canon or Epson, which entails replacing a seriously expensive 'print head'.
Jun 08, 2011 | HP PS C4780 All in One InkJet Printer
Canon Pixma ip2000 Inkjet printer wont print black. Replacing cartridge did not fix the problem.
Remove ink cartridges,then print head.
Clean print head with dry cue tips.
Apply strong suction over black print
jets on print head.
Replace print head and cartridges.
It worked for me.
Oct 17, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
After installing new black cartridge into printer will not print!
dear friend
this error due to filled waste tank You must replace waste ink tank.Visit u r nearest canon service location or dealer point
Jul 02, 2009 | Canon BJC 7100 InkJet Printer
Big black cartridge not printing
Try replacing your printer ink cartridges with a new one.Chances are you have bought a defective cartridge. If that does not work, pls try to check the slot for your black ink for obstructions, then replace your black ink cartridge.
Mar 07, 2008 | Canon i860 InkJet Photo Printer
152 people viewed this question
old marine
old marine
