Question about Dell Inspiron 1521 Notebook
Dell inspiron 1521 laptop won't recognize a new 90 watt power
I just bought a new power adapter for my dell and it will run but won't charge the battery. At boot up I get a unrecognized ac adapter error
  • 58 Answers
There are different types of Dell power adapters, some of them put out different amounts of power. While it is possible that the battery is faulty, it is more likely, given your error message that the adaptor is wrong. If you got it from Dell, you can call them and they will exchange it.
Cheers
Dave
Posted on Jun 21, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
My dell inspirion ac charger will keep computer running but will not charge my battery. A pop up will inform me that the system doesnt recognize the charger.
it could be a couple things: Are you using the standard 90 Watt ac adapter, or the Travel auto/Air adapter. The travel adapter is only 65 watts can will charge the battery
If using the standard ac adapter, see if you can try another Dell D series adapter and see if you get the same error.
If same with another adapter, the issue is the charging circuit. If another adapter works, then replace the adapter.
If the charging circuit is bad, it will be the chargerboard or if intergrated, the motherboard
Sep 25, 2010 | Dell Inspiron 1545 Notebook
My battery charges but the laptop wont run on the battery
If your power adapter appears to be charging your laptop battery, but the laptop will not run on the battery or only runs for a short time this usually indicates that the battery will not hold a charge and needs to be replaced. Although it should run fine with the power adapter connected.
Jan 26, 2010 | Dell Inspiron 1521 Notebook
Not charging batteries
It sounds like you are using a 65 watt AC adapter or an Auto Air Adapter.
The system needs a 90 watt adapter to charge the battery while the system is on.
Jan 20, 2010 | Dell Inspiron 1501 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
My inspiron1521 ac adapter is not recognize
You probably need a new AC adapter. The best option is to find someone else with the same laptop adapter and try theirs. If it works then you know you need a new adapter. You can try and go to a store and purchase a generic one for you laptop if you do not have someone to swap with and take it back if it does not work. If it is still under warranty then Dell will send you a new one.
Jun 14, 2009 | Dell Inspiron 1521 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1521 Notebook Logo
401 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
