Question about Garden
Electric PTO on 1500 series Cub Cadet won't engagewithengine hot
The electric PTO on my 1500 series Cub Cadet stops engaging when the engine gets hot. It first starts as delay between the time I operate the switch and the mower starting. Then it won't engage at all. I can shut the engine off for 5 minutes or so and it will work for a while. Then it won't engage again
  • 1 more comment
  • Anonymous Mar 24, 2014
    when pto is engaged engine stops running. is this from a bad safety switch
  • Anonymous Mar 26, 2014
    PTO will not come on
    reverse light will not come on, pto does not engage
I have a 2002 1500 series cub that had the same problem.
What it sounds like is the PTO switch, possably just the wire being burned in half.
Posted on Sep 06, 2009
  • 513 Answers
Its the electric clutch on the engine that engages the belt to run blades check the centrifical clutch or electric clutch
Posted on Jun 28, 2009
After reverse, my cub cadet zero turn mower pto will not re engage the blades. sporadic up to the point of stopping altogether. is it the switch or clutch?
I would guess it is the switch. My Cub Cadet has a safety feature where the blades (PTO) stop when you hit reverse. There is an override where you turn the key back about a quarter turn or so and hit a button right above the key to make the blades run even in reverse. Therefore, I would guess the ignition switch is the problem but I can't be certain. Or it could be the electric switch that engages the PTO.
Aug 10, 2014 | Cub Cadet Garden
Pto not engage when hot
Is the pto electric? if so it may hav excessive clearance between the clutches because of wear which would cause it not to be able to engage when hot
Oct 31, 2013 | Cub Cadet Garden
1806 cub cadet PTO blows fuse when engaged
check the pto switch..un hook it if thats it then replace
Nov 19, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have a 1999 cub 2135 with a kohler engine. the mower deck wont kick in . i ran a hot wire to the pto & it worked .do i have to replace the switch or the module. i also checked the seat switch &...
IF connecting that one hot wire to the pto made it engage then you either have a broken/cut/bad connection/wire to the pto or the switch is bad.
What you did by using the hotwire to the pto is bypass all the wiring and the switch for the pto.
You can determine if it's the switch real quick if it only has two connections/wires to the switch. Pull the switch, remove the wires and touch them together, after you have the mower in the condition under which the pto would engage. If the pto engages it's the switch for sure.
Take all the proper safety precautions. Don't let the wires touch anything else.
Sep 29, 2017 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Pto does not engage
snapper electric clutch not worjing has power to switch
Jun 22, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Garden Logo
1,449 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
