Question about Volkswagen Golf Vw Diecast Model
Vw golf has had diagnostic check found fault code P0023
The car is a VW GOLF 1.6 PETROL 52 REG, had diagnostic checks as light came up, diagnostic brought out fault code P0023 local garage says it needs further investigation, says can't say how long it will take or cost to fix problem.
could you please help, most appreciatied
kind regards
sam
  • 5 more comments
  • samkhan121 Jun 21, 2009
    hi, its 52 reg 2002, valkswagon golf, 1.6, 1598 cc its a mk4 if thats what you mean by v4 or v6
    regards
  • samkhan121 Jun 22, 2009
    the car doesnt pick up speed as it should do is what i feel, the rev counter at times revs a little the neddle goes up and down
    and can you advise could fault code P0171 be linked with the problem that you've told me because this code comes up too
    and thankyou for your quick response
    so is it best to have the camshaft sensor replaced and how much would one cost for my car spec
    thanks
    so let me get this straight ones causing the other, but which way round should i sort the P0171 and then check if P0023 still exists
    or sort out P0023 and see if thats cleared P0171
    to replace a MAF how much will it cost and how much for CAMSHAFT SENSOR
    thats great thankyou very much for your help
    much appreciated
  • Michael Masters
    Michael Masters May 11, 2010
    Ok, can you explain what symptoms you are experiencing at the time.
    Is the car missing?
    Dose this vehicle start or, crank up?
    Is there any smoke coming from the pipe?
  • Michael Masters
    HI, i will need the year model and, the actual engine size if possible. is it a V4 or V6?
  • Volkswagen Master
  • 2,200 Answers
This trouble code is related to a faulty camshaft sensor or to be more precise the camshaft position actuator circuit is open. There are 2 camshaft sensors on the Golf and the camshaft sensor that this code relates to is behind the timing belt. This code indicates that the solenoid that adjusts the cam timing has an issue - the circuit is open. The actuator itself may be faulty or if you are lucky it may be wiring related or be a bad connection to the actuator.
Posted on Jun 22, 2009
  • 2 more comments
  • Radio Code Pro
    Radio Code Pro Jun 22, 2009
    I should add this may cause the car to run poorly or feel underpowered, be difficult to start and cause the engine management light to come on on the dash.
  • Radio Code Pro
    P0171: I believe that fault is related to a lean fuel condition. In my opinion, the most likely cause of this is a faulty mass air flow sensor or a vacuum leak. In that situation I would have the car checked over - replace MAF if necessary (most likely this is the cause). I would then have the garage reset the ECU to clear all fault codes and see if P0023 (camshaft sensor fault) returns or not after driving the car for a while.
  • Radio Code Pro
    To have the camshaft sensor replaced will cost you around £400 in total. The actuator itself is around £265 and its behind the timing belt so costly in labour terms.
    I would seek advice from the garage about changing the MAF first in my opinion as this may be the cause of the timing issue not the other way round. At the very least if you decide or they advise you to change the actuator first. I would strongly advise you to get the timing belt and tensioners done whilst they are at it and in this way save you that labour expense at a future service.
    Reasoning is there will be no further labour charge for replacing the timing belt as they will have to dismantle that part of the engine anyway to get at the actuator.
  • Radio Code Pro
    MAF exchange unit from VW is about £70 - £80 and it's only 5 minutes to fit. Camshaft sensor is a different monster as outlined. Take advice from the garage on the best way to go as I don't want to put you wrong but I know the route I would go!
    As stated if you are going the camshaft route as a first port of call then get the timing belt changed while they are at it. At least then you will save a future service cost.
  • 6,784 Answers
Trouble Code: P0171
Fuel System Too Lean (Cylinder Bank 1)
Possible Causes:
Air leaks after the MAF sensor, or leaks in the PCV system Exhaust leaks before or near where the HO2S is mounted Fuel injector(s) restricted or not supplying enough fuel Fuel pump not supplying enough fuel during high fuel demand conditions Leaking EGR gasket, or leaking EGR valve diaphragm MAF sensor dirty (causes ECM to underestimate airflow) Vehicle running out of fuel or engine oil dip stick not seated
  • 6 more comments
  • Michael Masters
    Michael Masters Jun 22, 2009
    This will read better for you.
    Trouble Code: P0171
    Possible Causes:
  • Michael Masters
    The cam code is linked to these issues, it is confusing the ECM.
  • Michael Masters
    P0023 B Camshaft Position - Actuator Circuit (Bank
    2).
    the P0023 code is causing the P0171
  • Michael Masters
    The cam sensor will cost about 40 bucks tops.
  • Michael Masters
    Replacing the cam sensor will fix this issue.
  • Michael Masters
    If the original code given by the ecm was the P0023 and, the P0171 came last, i would recommend changing the cam sensors. this will fix the issue.
  • Michael Masters
    The Maf or, Air flow meter sensor in your case, will run you about 50 dollars and, the cam sensor will be 40 dollars.
    I would replace the failed Cam sensor first. this will clear the P0171 code.
  • Michael Masters
    no problem, glad to help:)
Plz mery smart code chayaya
Posted on Jun 02, 2012
I have a 2006 vw golf 1.4. The exhaust fault light has come on and using a diagnostic machine i have found that fan relay no1 is faulty. Can anyone tell me where this is so i can replace it?
The fan has nothing to do with the fault for the exhaust. Please see a dealer on this, you need a VW approved live data scanner to check this out.
Mar 20, 2014 | 2006 Volkswagen Golf 1.4
Vw bora 1.6 s 52 reg emmisions warning light came on.
could be but i suspect the wires on the lambada sensor or the lambada has packed up`,get someone to plug it in and read the lambada temperature readings
Apr 20, 2010 | 1999 Volkswagen Golf
Code fault po600 on my vw golf 1.6 automatic
I don't see a P0600 but you can check here at Ross-Tech.
Apr 06, 2010 | 2004 Volkswagen Golf
Emmissions light is on on my 1.6 vw golf its a 52 reg its got an mot on tuesday will it fail this can i turn light off myself thanks for any advise
cheapest way to find out is take it to a skoda dealer(labour rate less than vw)and ask for a diagnostic check,will cost but you will have all info to rectify any item before mot.(even if you take out the bulb the mot
checks the emmisions).the mot will not tell you, if it fails, what is wrong.....
Mar 13, 2010 | 2002 Volkswagen Golf
2000 vw golf stops while driving on the highway
Maybe you magnetic wheel sensors are contaminated or need replacing, that's what sends the data to the ECM. A faulty wiring could also cause sporadic occurrences when a problem acts up.
Feb 19, 2010 | 2000 Volkswagen Golf
VW Golf engine revving when idle
If its fuel injection,it could be the throttle body needs cleaning or replacing and basic settings need to be done with a suitable diagnostic machine
Jul 26, 2009 | Volkswagen Golf V Vw Scale Diecast Model
Vw golf 1.4 2002.diagnostic fault codes;4076 temp
The parts aren't really that expensive, it's the labor these places charge an hour. Call around and see who can do it the cheapest, unless you want to do it your self.
Jul 22, 2009 | 2002 Volkswagen Golf
Vw golf mk4 2.0
If the check engine light is on look at the faults. It could be a defective cam sensor, the timing belt might not be in the place, or a defective mass air flow sensor.
Aug 31, 2008 | 2000 Volkswagen Beetle
Volkswagen Golf Vw Diecast Model Logo
2,740 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Bogdan Odwazny
Bogdan Odwazny
JonSnell Electronic
JonSnell Electronic
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
