Question about Kenmore 72056 Air Conditioner
Through wll airconditioner compressor turns on but
Through wall airconditioner compressor turns on but turns off 2 or 3 seconds later
    Sergeant:
    Champion:
  • 208 Answers
Check to see if the compressor is working
Posted on Jun 21, 2009
  • jrnbudd Jun 22, 2009
    i bet it needs a charge
Why does my Dometic caravan airconditioner turn itself off after a few hours and won't restart for hours later?
There is a temperature controller safety switch on the compressor under the plastic cover for the wire connections. You need to determine the reason it is tripping first, so you can correctly diagnose the problem. If the compressor is indeed running hot there is probably a lack of freon or an internal motor winding problem. If the compressor seems to be at a normal temperature(High side of warm but not burning hot)then look to replace the temperature switch.
Jul 03, 2014 | Cars & Trucks
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
I have just purchased and installed a Samsung AQ12FEN. A qualified Airconditioner company installed the unit. The slpit unit installation is a back to back configuration It replaced a 8 year old split...
This could be caused by an installation problem. The system could be severly overcharged, causing the compressor to load up and can cause a failure. i would start there. Is your intaller qualified to install these systems? (does he know what he is doing?)
I recommend, checking the refrigerant pressures first. You can also check the Polarity of the high voltage in to the outdoor unit. If the compressor is an Inverter Drive compressor, and the polarity is reversed, the compressor can run backwards causing the noise and eventual failure. To correct a polarity problem, simply remove the 2 high voltage wires that feed power to the outdoor unit from the board or contactor. Then reconnect those 2 wires, in the opposite position. (say you take loose from the unit and the Black wire is on the right side, and the white wire is on the left side. Simply swap sides, reconnect the Black wire on the left side, and the White wire on the right side.
Hope this helps,
Brian
Dec 15, 2010 | Samsung Heating & Cooling
Installed Amana 12000 BTU wall pack type airconditioner yesterday. How do I get machine not to turn off and on during operation? Do I set it to run automatic? If I set it "cool" low stetting at 69 degrees,...
You definately want the compressor to shut on and off with the demand set by the thermostat. It is no different than a full size home split heating and cooling system. You set the thermostat for the temperature you want and then you let the system decide when to run the compressor
Mar 09, 2010 | Heating & Cooling
The fan runs constantly. The compressor starts,
Check the compressor run capacitor first.
Jun 21, 2009 | Kenmore 53701 Dehumidifier
C6 error on airconditioner
6 - DC Peak Error
• Supplied power is not normal
• Comp Connector (CN-U,V,W) is disconnected or inserted to wrong
position
• Compressor is damaged (coil short) ? replace compressor
• Too much Refrigerant
• Defect in outdoor pcb assembly ? replace pcb assembly
Try turning power off to external unit, usually resets diagnostics and runs OK. If not PCB external unit likely culprit, replace!
Jul 31, 2008 | Heating & Cooling
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Kenmore 72056 Air Conditioner Logo
184 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
