Question about Dryers
I have a simpson maxi dry 452 dryer that has a broken door hinge. Still works fine and appears to be a simple case of replacing the hinge. Is it possible to purchase the hinge ?
SOURCE: Simpson Sirocco 350 Dryer not heating
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Posted on Feb 25, 2009
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Posted on Sep 20, 2009
  • 713 Answers
SOURCE: Broken door on simpson maxidry 362
when it comes to whitegoods old is good. your dryer will outlast most new ones. buy the new parts it will b lot cheaper than a new dryer. not much goes wrong with the old simpsons. please reply if u need more help
Posted on Apr 11, 2010
SOURCE: Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Posted on Jun 29, 2010
  • 713 Answers
SOURCE: I'm looking for a Simpson maxidry 456 second hand
Hi just read your posting.What country are you in?If it is AUSTRALIA then I can help you.Also if it is Australia then which part?Looking forward to your reply.
Posted on Sep 21, 2010
Kenmore HE5 dryer. Is there an adjustment for the door, it pops open while drying. Appears that the bottom of the door hits before the top, we have to push the top of the door in to get it to latch
if the catch isn't broken sometimes i've seen the hinges out of shape,i open the door stick a screw driver in both sides at the bottom of the door where the hinges are and close the door and push on the top of door,don't go crazy just a couple of light pushes this will make the door close better,hope this helps,look at the plastic catch in the door where the strike goes into,if this is cracked or worn the door will pop open,next time open the door,find the tag and send the full model number
Dec 27, 2017 | Kenmore Dryers
I have a Simpson Ezy Loader. I need to replace the door hinge which I have purchased but I am unable to get the broken door hinge out of the door as the door wont come apart.
may i ask why are you replacing the hinge? the door is in two halves and held together by a few large screws, once you remove the screws you will need to put a flat blade screw driver in between the two halves of the door and pry it open, theres a heap of tiny clips that hold the two pieces together, it will be quite hard and may make a loud crack when you pop it open, dont worry you wont break anything.
Feb 04, 2017 | Simpson Washing Machines
I have a simpson maxidry 1200s and it appears that a piece has dropped off inside where the door hinge attaches to. (The door is perfect - Its the part inside the main body of the machine that the part...
i believe this is the part, if not you will/can find it at this site. Good Luck Tim:
http://www.repairclinic.com/Frigidaire-Dryer-Latch-Parts
Mar 02, 2011 | Dryers
Loud piercing noise when drying
It doesn't work at all dot_lineone.gif 1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.There's no heat dot_lineone.gif 1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting. It takes to long to dry dot_lineone.gif Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Dec 21, 2010 | Maytag MDE2400A Electric Dryer
Apr 11, 2010 | Dryers
Simpson Maxidry 1200 S Cloths Dryer. Our dryer whilst spiining and heating is not adequately drying clothes. When I took it down to check test it appears that the belt to the central lint fan may have been...
Yes - the vent exhausts humid air, and draws IN fresh dry air. So the humid air is staying trapped in your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Washing Machines
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
3. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
May 31, 2009 | Kenmore Dryers
I have a Simpson Atlas Apollo oven, but the oven door won't close tight, can the hinges be adjusted or will I need new ones, they look fine?
The springs in the hinges are probably tired. There is no adjustment you need to buy new hinges for about $50 for a set. Changing the hinges is a fairly simple operation for a person of average dexterity. I've just done the job on our oven.
Jan 01, 2009 | Kitchen Ranges
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
Marvin
Marvin
