Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Was running fine then popped loud now it turns over freely but want fire could it be a slipped keyway
  • rscamaro73 May 11, 2010
    What were you doing when the noise happened ? Cutting grass ? Hit something ? Just idling in place ?
    Where exactly was the noise ? Are there any other noises now, or any leading up to this ?
    Problem Solver:
  • 19 Answers
Could be
Posted on Jun 23, 2009
Cub Cadet won't start and engine make a popping sound
popping is firing order not right or the timing has slipped.
Jul 02, 2017 | Cars & Trucks
My drum stopped turning. Heating element is fine. Timer is fine. Push start button is fine. I can spin the drum freely and manually. Possibly heard a large pop. Any suggestions?
If you heard a loud pop, then I would definitely say that you have a broken belt. As far as the blower not working as well, if you are having drying times that are taking longer, then you should check your vent line for blockages or build up of lint. Hope this helps!
Jun 27, 2015 | Dryers
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
Idle fine give gas brakes up pops new coil like out of time all mart are right crank h
can i buy a comma? says Vanna White, LOL !, i cant understand that.
brakes up pops? the cars foot service brakes, fail?
new coil, car has 10 or more coils which one, is a problem.
no year stated (fail)
no engine option stated (fail ) and country. fail 3.
Jeeps are sold all over earth, in 3 types. and postal an police, (5)
1984 ? 2001? i6? v6?
the only word i found , clear was pops
this is back fire, but to intake side or exhaust.?
intake side is bad spark timing.
exh side is gross over fueling and cracks in the exhaust pipe,
causing what is called, muffler explosions... loud report
the intake pops are back fires and is a not so loud , cough. sound.
or hickup
induction back fire is 90% bad ignition, and 10% causes by huge lean conditions.
Engine posts:
does it run bad, cold , hot engine or both?
does the engine run bad, even raced, in neutral , or cold.?
does the engine misfire at any time. say when?
does the engine bog, (lost power up hills or any time)? explain when.?
Jan 12, 2014 | Jeep Cherokee Cars & Trucks
Loud knocking coming from lower timing cover area 1995 toyota camry 2.2
I do think that loose key and keyway could cause the knock. It would also explain the loss of power, due to the engine timing not being spot on.
A knocking big end or main bearing would not improve at higher revs, it would get worse.
Act soon before the keyway in the crankshaft itself is too badly damaged, by removing the crankshaft pulley, lower timing belt cover, and belt guide. You can then get a precise idea of what exactly is worn. This may assist
http://www.turboninjas.com/camry/eg1.pdf
You may actually have to find an oversize key, for a neat fit in the crankshaft. It may be necessary to file or grind it to fit. Engineering supply houses stock them, eg
http://engtooling.com/webshop2/
Dec 04, 2011 | 1995 Toyota Camry
Tail pipe making loud popping noise while idling
Sounds like it's back firing. Check your timing belt. If it has issues get it changed immediatly. If the belt slips far enough you can destroy your valves.
Aug 18, 2011 | 1991 Honda Civic
Having trouble to get it running it fires but wont run i have new plugs and cleaned the carbi and fuel on a bolons st 120 1990 modle ridermower
choked? bad gas. gas sitting for only a few months will go bad. Spray some WD40 into carb and try to fire. if it runs replace gas. Check to be sure keyway has not slipped
Mar 05, 2010 | Garden
My turbo won't boost its starts to shake and pull back
Check out all your air hoses and clamps and check the turbo itself to make sure it spins freely. (Engine not running)
Nov 11, 2008 | 2004 Dodge SRT-4
Vacuum is making a loud noise
Is the smell rubber or electrical. If rubber then the belt is slipping and needs to be replaced, they stretch after awhile. Also is the brush roll turning freely, or is it bound up, it may have to be replaced. If the smell is electrical, then probably the motor is going bad and will have to be replaced.
Dec 03, 2007 | Kenmore 35622 Upright Vacuum
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
342 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
