Question about Gateway M6307 Notebook
Gateway model m6307 screen won't turn on, the laptop turns on but not the screen
  • demonwolfe21 May 11, 2010
    most likely it could be a loose power coupler from the motherboard to the screen. I suggest contacting the manufacturer and gaining information on refurbishing. I had a similar problem where the screen did not appear to power on. In that perticular case the hard drive was erased by a magnatized panel on a store counter. the screen powered on but no information showed so it remained blank due to HD being erased,
  • 484 Answers
Function Keys (Fn Keys) F5, F6, and F7 all have some level of control over the monitor displaying with an external monitor plugged in or not. Even with a monitor not plugged in, the keys will disable the laptop's monitor.
Yoy should try those keys one at a time, until you find the one which actually does allow the monitor to work, even without an external monitor.
That may do it for you.
Posted on Jun 21, 2009
    Sergeant:
    Champion:
  • 240 Answers
Remove the battery and then put it back after about 5 mins. Plug it into mains and see if that solves it. Sometimes when laptops "hang" like this-removing the battery solves it.
Tiene bluetooth la gateway 6307
You will find out if you try the following. To turn the Bluetooth radio on: 1 Enable the Bluetooth radio by sliding the wireless network switch to the ON position. If the Bluetooth radio does not turn on automatically, press FN + F6.
Jun 18, 2014 | Gateway M6307 Notebook
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
M6307 powers on goes to the loading bar and then nothing. also will not load from the recovery disk ??
Just before it boots, go to the BIOS option and set the first boot device as the DVD/CD Rom.
Place your rescue disk in the drive and re boot.
Jan 06, 2011 | Gateway M6307 Notebook
Gateway m 6307, won't turn on, the lock icon is on near the mouse pad,but wont turn off with funtion lock.
The problem could be that the keyboard is not operating correctly try to install usb keyboard and see if you can hold the function key on the bottom left and press the Scroll lock key at the top just to the right of the F12 key.
Nov 28, 2009 | Gateway M6307 Notebook
My Gateway M-6307 Notebook wont turn on
Ezra, It could be: 1. Dead battery due to faulty Charger. Check the voltage of the charger output. Replace if dead. 2. Dead battery NOT because of charger. You can check it by plugging into the wall socket. Replace if found dead. 3. Faulty power jack on the laptop. Replace it if battery is fine. 4. Faulty power on switch. Needs a replacement. 5. Fault ahead of the switch, then need a professional job.
Nov 08, 2009 | Gateway M6307 Notebook
Gateway m6307 laptop, webcam is not functioning
Regarding on your problem, please go to your the device manager and removed the web camera from there and restart your laptop. Upon the restart of your laptop the operating system you have installed in your laptop will automatically detect new device(your webcam) and installed the drivers automatically by the auto-installation wizard of your laptop.
Thanks
Aug 27, 2009 | Gateway M6307 Notebook
GATWAY MODEL M6307 WON'T TURN ON
I had this problem assuming that it is the same. Possible solution, (worked for me); With Laptop unplugged, hold down 0, (Zero), key for 30 seconds. At the end of 30 seconds keep holding 0, (Zero), key down and plug in and press the power button.
*I had to press power button a 2nd time*
Computer powered on and booted, though it took nearly 20 minutes for me to get a boot screen for windows; I could only get a choice for Bios. But aftr about 20 minutes of just waiting the Boot screen changed to the normal Boot Menu and I was able to get Back into Windows no problem.
I think I tracked the issue down to a Windows update, but a still trying to define which one specifically.
If this doesn't work; See previous Answers about Power supplies and cords.
Jun 21, 2009 | Gateway M6307 Notebook
Gateway M-6307 power dies on boot up (reaches widow screen dies)
Make sure that it must be charged. If you are sure, there might be a problem of overheating.
If you check, there is a CPU fan. Overheating might cause thie.
Use a vacuum to cool on the fan to make it spin manually, hmmm it actually started to work after that.
If not, let me know.
Thanks for using "Fixya".
Jun 18, 2009 | Gateway M6307 Notebook
M6307 Gateway Laptops overheats and shuts down
Have you called Gateway? This is definitely a mother board or CPU problem, both probably caused by a slow acting fan. Gateway should replace these.
Jan 05, 2009 | Gateway M-6307 Notebook PC
Gateway M6340U hard drive problem
It sound like memory problem. Change the memory and test if the problem is solved.
Dec 11, 2008 | Gateway M6307 Notebook
Gateway M6307 Notebook Logo
213 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
