Question about Ruud Matching Split Air Conditioner
Air conditioner runs all the time but temp still goes up
Just sarted doing this even had the coils cleaned service man thought that would take care of the problem but is has not. I checked the little pipe it is warn but not hot and the bigger one is cold. I have made sure all of my filters are clean. I hope you can give me some advise in this matter.
    Sergeant:
    Champion:
  • 208 Answers
Temprature control in need of repaiir or replace
Posted on Jun 21, 2009
Cold start low ideling
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
May 19, 2017 | Mercedes-Benz Mercedes 190E 2.3-16 Diecast...
Is there a manual for preventive maintenance?
every 3 months and more in the summer I spray my outside unit with a garden hose. I start at the top of the grill and work my way down. dirt and grime will come out the bottom. jeff
May 27, 2013 | Ruud UAKA048 Air Conditioner
My mother in law has a Ruud 10 Seer air conditioner. She's had it since 1998. The air conditioner runs fine but it will only cool the house now during early morning and evening hours. It no longer...
couple thoughts hee. 1. If you allowed the filter to get really dirt you might well have a "blanket" on the evaperator coil that is not allowing enough air to move over the coil. 2. Low on charge. 3 the compressor is getting ready to give up the ghost.. Bad valves? Check and see in the afternnons if the suction line at the compressor is wet or cold. be careful when touching these lines as the discharge is HOT... But my guess is low charge... Bad compressor..
Jul 14, 2011 | Ruud Matching Split Air Conditioner
How can i make my air conditioner cool down,
A/C units are all designed for a 20 temp drop and a normal temp. setting is no lower than 72 degrees or the indoor coil will freeze, and this is if everthing is perfect. If the filter is dirty either coils are dirty and I mean clean enough eat off of. The coils have to breath or flow enough to pick up and reject the heat, you should be able to see thru the fins unless the are very tight. Out door coils use a garden hose and nozzle and use as much force as possible and be very methodical, both coils are air filters and get dirty, the indoor coil use a pump up sprayer or a spray bottle, if the coil is over the furnace watch the water so it wont run into it. There could be something going on but if you were to call a service man in he would charge you for this, and them proceed with his service. If the coils are clean you must be using a good filter indoors, or its dirty, clean the coils and use a good pleated filter and keep the coil clean. Hope this helps.
Jul 01, 2011 | Emerson Heating & Cooling
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Feb 23, 2010 | Ruud Matching Split Air Conditioner
I have a dometic Roof Top Rv Air Condtioner and the evaporator coil is freezing up. Could the unit be low on freon. I also noticed the evaporator coil had a noticable amount of dust build up. My thought...
It freezes because of a lack of air flow ... and/or ... colmplicating ... high demand with high humidity.
Even worse is running the roof top with the door open in the summer (I see this all the time in the RV park where I work - I'm not saying you are doing this - but I see it all the time. What the heck, the typical transient camper is not paying for the electricity - let it run!)
I hope this helps you
thanks for your interest in FixYa.com
a
Dec 11, 2009 | Dometic Rooftop RV Air Conditioner
Is the Air Conditioner our problem?
If the intake vents are occluded in anyway or debris surrounds the coils this will cause the internal temp to rise to critical and trip the power. Unless you are skilled and agile and have a knowledge of how to open the unit I would be saying get a professional to look at it in case it goes further than thye basic problem as a result of overheating several times.
The last thinhg you need is no A/C in hot periods and a few hours shopping whilst it is being looked at by an A/C tech is well worth the visit before it costs more by not diagnosing another problem early
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Not cooling house. Its never worked.
Check and see if the inside and outside coils are cleaned , if they are , have someone come out and check the freon in the unit it can leak out over a period of time.
Jul 20, 2009 | Weather King 10PJA2501AH Air Conditioner
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Ruud Matching Split Air Conditioner Logo
225 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
