Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Help my hunter thermostat wont cool off my house til 900 pm every nite...any ideas?
  • steph7493 Jun 24, 2009
    we ended up having to spend 400 dollars to get a fan motor plus compassitor and had too much freone..weird..well it saved my mother in law from buying a air conditiong....
  • 672 Answers
Not sure, but could check - manual/program setting. there may be a program running, if so just turn to manual. Check owners manual or manufacturer website for instructions for programming
Posted on Jun 21, 2009
Hi any ideas on why this happens, I have a a honeywell CM67NG wireless thermostat and it fires up the bolier(Alpha CD50) even when I have set the programmer for times and days. example I have set it to...
One possibilty is the therm has a antisipator setting, meaning Ex; at 7:00 you want 72*f,but the house is 62*f at 6:15 the therm will bring on the heat early so the house will be at 72*f@7:00.There should be a short lag if it is comming on at 4:00 it is something else.
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
I bought a house with a Hunter # 44100A programmable thermostat but have no manual to program it from. How can I program it?
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Aug 17, 2010 | Hunter Heating & Cooling
I have an Hunter Indiglo 44250 thermostat. I changed the batteries and now have nothing on the screen at all. I tried resetting it already and nothing is happening. Thanks!
Having a problem with my fan staying on continuously even after my furnace has finished heating. Cool air blows throughout the house all day and night.
Aug 09, 2010 | Hunter Fan Company 5/1/1 Programmable...
Flashing time on a Hunter Programmable Thermostate #44665
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Jul 22, 2010 | Hunter Fan Company 5/1/1 Programmable...
From hours of 12 pm till bout 6 pm my ac doesn: wana kick on but when it starts cooling down my central unit works all nite kickes on and off like it suppose to could it be the compressor or compasitor
Do you have a programable thermostat? It probably is not the capacitor, maybe the compressor overload
which cuts the unit off if it gets to hot.
Have you cleaned the condensor?
Jun 30, 2010 | Heating & Cooling
Thermostat control
I would like some help programing the thermostat in my house. Hunter, Model 44300A
Thanks,
May 05, 2008 | Hunter 30124 Air Conditioner
Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
275 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
