Question about Mitsubishi HS-U748 S-VHS VCR
Program remote I got this at a pawn shop we do i get codes so i can use tv and vcr
0 characters
1 Points
How to operate with remote control
VCR Remote Control Buying Guide ' eBay > ... > TV, Video & Audio Accessories > Remote Controls
Finding a suitable VCR remote control to operate a combo unit involves finding a remote that supports the functions of each component of the unit. The key to ...
Jump to Operating In VCR mode - Your remote control is designed to operate many functions of your VCR. To select your remote's VCR mode:.
Program and Operate Your Cox Remote Control
Cox CommunicationsApr 28, 2015 - ... on how to operate and program the buttons on your remote control, select from ... Index of Remote Controls ... Program TV, DVD, VCR, Stereo.
VCR remote control codes ' FiOS TV ' Residential Support ...
Jan 14, 2016 | VCRs
Remote CTL model RM-V210 doesn't allow programming of the VCR.
Dear sir/madam,
click the above link and programmed your remote control..
good luck
Oct 01, 2008 | Sony SLV-679HF VHS VCR
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
What are the charges for repaing a Sony Beta Mac VCR player or do you have a used one for sale.
Go to E-Bay Look under Electronics TV/VCRs thier you will find alot of good deals or Try local Pawn Shops I have seen them there for only 25.00
Nov 19, 2009 | Sony PVW-2800 VCR
Remote codes
Hope this helps.
Feb 27, 2009 | VCRs
Remote control codes
RCA Universal Remote Control Programming Codes
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
Find codes for device and brand below.
  1. Press and "HOLD" CODE SEARCH.
  2. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  3. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
RCA Codes for VCR
Nov 04, 2008 | RCA VR557 VHS VCR
Lost manual to program remote for Toshiba M-68C VCR
-Push "TV" and release.
-hold prog and enter the two digit code. (Try 10 for a phillips) release the prog button and see if it worked.
If not try experimenting with other two digit codes as I don't think there is an auto search for this remote. At worst it'll take 99 attemts to work ;-)
Feb 03, 2008 | Philips VR330 VHS VCR
Remote control code
That doesn't sound quite like the usual procedure for programming a universal feature on a remote. Should have to put the remote in TV mode, then press something to get it into programming mode, then put in the code for your particular TV.
Oct 17, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Mar 10, 2007 | Panasonic PV-V4021 S-VHS VCR
Mitsubishi HS-U748 S-VHS VCR Logo
14 people viewed this question
Top Mitsubishi VCRs Experts
Are you a Mitsubishi VCR Expert? Answer questions, earn points and help others
