Question about Uniden PRO520XL (40 Channels) 2-Way Radio
I have pro520xl with very poor tranmission on my jeep with a 4 foot wip off the back of the top tail light
2 Suggested Answers
  • 13 Answers
SOURCE: Poor tranmission with my Uniden PRO520XL
its a cheap antenna get a wilson 1000 or 5000 antenna and it will talk a hell a lot better
Posted on Nov 11, 2009
What antenna
If you cannot use a magnet mount antenna on the roof then a fiberglass antenna (top loaded) about 4 ft. tall mounted behind the cab on the bed rail.You can usually run the coax thru a rain drain hole in one corner of the bed. The antenna should be tall enough to where the top third of the antenna is above the roof. The taller the ant.is the better the SWR will tune.
Jan 20, 2014 | Uniden PRO520XL 40-Channels Base CB Radio
Number plate light bulb replacement
WATER GETTING INTO THE TAIL GATE THE FIX 1, CORROSION THE THE PLUG BY THE N/S NOT USE REAR FOG LIGHT 2, CORROSION THE WIRING LOOM PLUG IN THE BOOT N/S 3, CORROSION THE THE PLUGIN THE COMFORT UNIT UNDER THE CARET FRONT PASSENGERS SIDE FOOT WELL 4, A 5 AMP FUSE MINE WAS NUMBER 4 IN THE FUSE BOX DRIVERS SIDE OF THE DASH 5, WATER GETTING INTO THE TAIL GATE THIS I FOUND WAS THE PLASTIC SEEM AROUND THE NUMBER PLATE, LOOK VERY CLOSELY AND YOU WILL SEE WERE I MEAN PS IF YOU HAVE THE TAILGATE UP TO A BIT AND OUT SOME WATER ON THE NUMBER PLAT HOUSING YOU WILL SEE WERE IT GETTING INTO THE HOUSING , A MOULDED PLASTIC SEEM SOME SILICONE SEALANT SORTED THAT OUT HOPE THIS HELPS SOME OTHER POOR SOD OUT
Jan 05, 2014 | Car Audio & Video
Hyundai 8 stitch sewing machine confused beginner!?????
Not familiar with your machine, but an important suggestion for all sewing machines:
ALWAYS RAISE the presser foot when threading the top thread. If you did not do this, remove the top thread completely from the machine and start over by RAISING the presser foot and following the thread path. (Do NOT miss any thread guides or thread any out of order!)
Lower the presser foot and thread the needle. (The top thread will pull through the needle ONLY if the presser foot is raised!) RAISE the presser foot and pull at least 5 inches of thread through the needle. Insert your fabric. Lower the presser foot. Hold the thread tail gently in your left hand and with the right hand manually turn the handwheel one rotation. The needle should pull the bobbin thread up through the fabric.
While still holding the top thread tail, "sweep" under the presser foot with a stiletto, scissors, a nail file (anything that will fit under the presser foot) to pull the remaining bobbin thread tail above the fabric. Grab both thread tails and pull them under the presser foot toward the back of the machine. Now, you are ready to take your first stitch.
You can gently hold those thread tails while you slowly power the machine to take the first couple of stitches on your fabric.
Jun 27, 2017 | Sewing Machines
Driver side brake light is not working. Replaced bulb, but didn't need to it is the same bulb that works the tail lights, which still worked. Ugh, 2006 jeep liberty. Someone said it was a brake...
THAT RIGHT IF BRAKE SWITCH BAD NO BRAKE LIGHT WILL WORK.SPRAY ELECTRICAL CLEANER IN BULB SOCKET BULB SOCKET COULD HAVE OXIDATION AND CORROSSION CAUSING POOR CONTACT.
Sep 12, 2011 | 2006 Jeep Liberty
Tail lights and parking lights not working on a 1993 jeep wrangler...replaced fuse
do you have a trailer wiring harness installed? very often this is poorly done, a causes a lot of problems with rear exterior lights.
Dec 21, 2010 | 1993 Jeep Wrangler
I have a jeep grand cherokee 2001, my tail light on the drivers side dosen't work, i replaced the tail light assembly, and it worked for a couple of weeks, now it's not working again, the turn signal,...
Tail light and backuo light are separate circuits. Backup light is under the control of the backup switch located on the shift lever or transmission. Thats why one might work right and not other. Most troubles of this type are due to poor ground connections Check again what you did to change the tail light assembly
Jan 05, 2018 | 2001 Jeep Grand Cherokee
When the lights are on, all rear bulb are fine. When you press on the breaks, the break lights are fine. When you press on the breaks when the lights are on the right rear goes completely dark.
Hi remove the tail light and remove the electrical connector then remove the top globe by twisting it anti clock wise then bend the contacts on the tail light up slightly and install the globe and tail light back
Nov 01, 2009 | 1999 Jeep Grand Cherokee
My tail lights are not working properly. When I
I agree with shannongreer but also check on the swith at the back of the brake pedal. It's near the top of the pedal almost under the dash.
May 13, 2009 | 2000 Jeep Grand Cherokee
you need a swr meter to check your standing wave.
Apr 07, 2009 | Uniden PRO520XL (40 Channels) 2-Way Radio
Uniden PRO520XL (40 Channels) 2-Way Radio Logo
42 people viewed this question
Top Uniden Radio Communications Experts
Steve
eradiostore
eradiostore
Marvin
Marvin
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
