Question about Craftsman Garden
It is a 12 AMP Craftsman 900-79694 edger and I cannot find the specs anywhere on the Web to know the size blade to get. thanks
  • panilling9
    panilling9 May 11, 2010
    could you double check your edger mod# you gave to verify it is correct?
    Thanks.
Are you sure it is not Model 900.79654?
Posted on Jul 18, 2009
How to stop trimmer line spool from spinning off
I bought a Shakespeare Push-n-Load 3 blade trimmer head at The Home Depot for about 26 dollars and picked up a pack of 12 replacement blades for another 7. Did a whole 3 acres worth of weed whacking and still didn't need to change the blades. I was also powering through some pretty thick bushes with ease. Highly recommended.
Apr 13, 2013 | Craftsman 25cc Gas Line Trimmer
12 hp roper lawn tractor need belt size for blade drive
take a piece of rope and run it around all the pulleys a mower shop or parts store can match it to that
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Blade wanders whenever cutting. Presently using an 1/8 in. blade. Tensioned properly. Have a 12" Craftsman band saw. Had to change double pully with an automotive single pully approximate size as...
What shape are the upper and lower guides in? Also, is the table at 90 degrees? Even a small error can make cutting less reliable if the table is not right on spec. It happens with my drill press sometimes, making the bit try to wander.
Jan 26, 2018 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Trying to replace the blade on my Craftsman edger; the nut holding the blade won't budge - now I'm not sure which way to turn it to get the blade off!! Clockwise? Counter-clockwise? Thanks. Larry...
Take a little break and spray the shaft where the nut is on it with some PB Blaster or Liquid Wrench penetrating oil. Let it soak tonight and turn it off counter-clockwise tomorrow. If you can fit a good sized box wrench on in, turn the wrench down towards the ground and give it a few good whacks with a rubber mallet or hammer. Try not to strip the head of the locking nut.
Oct 29, 2010 | Craftsman Garden
How do i change the blade on a craftsman edger?
also check the coil see if you get spark
Dec 13, 2017 | Craftsman Garden
We need a new blade for our craftsman edger
Go to www.searspartsdirect.com. Put your model number in of your edger.
It will show you a parts list , which will include your blade.
Hope that helps.
Good day.
Oct 23, 2009 | Craftsman Gas Mini - Tiller/Edger
I wish to know if I can purchase new blades for my hedge trimmer model number 900.799740 . Can I replace blade with 22 inch or longer size? Can original blade be sharpened? What new model is compatable?
Go to www.partsdirect.com, this is sears website for parts. You should be able to find the part number for a new blade.
If the blade has bolts and nuts holding the blade together it can be sharpened. If it is riveted together, it can be but it is more work than what it is worth.
Sep 25, 2009 | Craftsman Garden
Trouble un-screwing edger blade bolt
It may have left handed threads and needs to be turned clockwise to unscrew. As for sharpening an edger blade...it won't cut any differently. That short blade, traveling that fast and rubbing against concrete is going to do it's job, sharpened or not.
Jun 20, 2009 | Garden
Garden Logo
428 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
