Question about Whirlpool LSQ8000 Top Load Washer
How do you take the top off a whirlpool sq 9030pq5 washer
It poured water all over the floor when I was trying to fill it. There are no leaks out of the back. Please help asap!
    Sergeant:
    Champion:
  • 208 Answers
Look on the back there should be screws it hooks in the front and metels screws hold the back most likely
Posted on Jun 21, 2009
Started a load of clothes and it filled up with water. Why wouldn't it do anything else?
you will have to drain the water out by hand or by lowering the drain hose to the floor and letting the water pour into a bucket. Once you have it empty, tilt the washer back and remove the pump, you mostlikely have something in there stuck. That washer sometimes runs the drain motor when its trying to sense the load.
Mar 25, 2015 | Whirlpool WTW4800XQ 3.4 cu. ft. Top Load...
I have a whirlpool ultimate care II washer. When I start the washer, water pours in but does not fill up the washer. The water immediately drains away. Its not leaking out of the washer. I think the...
This issue calls siphoning effect. It happens when the drain hose was somehow lower or not stand vertically. It causes no air pressure column in the drain hose to keep the water out. Check the drain hose and make sure it is high enough. Try to hold the drain hose straight up and see if it is happened before having further inspection.
Oct 05, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaking water when filling and leaking lubricant on floor under washer
Sounds like symptoms of transmission going out, especially the seal. It is not cheap or easy to fix. Best bet is to look for a new or used washer.
Aug 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water pours out from washer underneath
The most common leak for those washers is from the drain pump a really easy and inexpensive repair. It is located underneath toward the front. To diagnose turn on water to tub fill 1/4 the way, pull out machine about 2 feet, tilt backward,you can use a mirror, I just poke my head under. is should be clearly evident where the leak is. The tools to change the pump it requires a screwdriver and pliers. There are two clips and to hose clamps,remove and replace in reverse order.
Mar 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Duet leaking
leaking water inlet valve very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
My washer, while draining, leaks from the bottom.
remove the panel to observe the drain hoses while machine is in use. using a flashlight, locate the hose that you see leaking.
May 31, 2007 | Whirlpool LSQ8000 Top Load Washer
Whirlpool LSQ8000 Top Load Washer Logo
88 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
