Question about Sony Cyber-shot DSC-W50 Digital Camera
My camera broke!
I turn my camera on, it says access, then the lens just starts going crazy, and back and forth, in and out. i really dont want to pay money to fix it, because ive already had it fixed once before. and i tried other things people told me to do, like hit it against my palm 3 times, but that didn't work. someone please help me!
  • 11 more comments
  • melindabeth Nov 05, 2007
    Same problem. Please help.
  • pinky23 Nov 15, 2007
    Camera powers up, lens pops out and the screen says 'access' and remains blank, camera then says switch off. Have tried wacking it but the fault persists.
    Oddly enough it still allows access to pictures on the memory card and scrolling through is no problem.
    Any suggestions before a really good wack with a hammer ends its life!
  • Anonymous Nov 16, 2007
    i have the same problem
  • kroberts1654 Dec 26, 2007
    ugh! me too! so frustrating... estimates for repair are over half the cost of a new camera! anyone have any ideas?
  • Jennilicious Dec 27, 2007
    I have a camera and my little sister dropped it!! It didn't want to turn on. Then after a while it did, but the lens are all mest up and when i connect the usb cable to my computer my camera turns off! any suggestions?? By the way you can't see nothing when you take pictures! I wacked it and I charged it but NO didn't work!
  • Fran73 Jan 03, 2008
    Hello!
    I have the same problem with my Sony DSC-W70!!!
    Lens going crazy in and out and always "restart the camera" message!
    Please, help!
    Thanks
    Fran73
  • Anonymous Aug 06, 2008
    like some others,I also am confronted with the infamous 'access' frame together with a lens that pops in and out when it feels like it.Shots on the memory stick can,however, be recalled but only after the camera has instructed me to turn the power off and on again.The camera is reluctant to switch off unless I point the lens down,away from the light.any suggestions?
  • Anonymous Aug 09, 2008
    mine does the exact same thing says access then lens go crazy then it says turn power off and on again. HELP!!!!!!!
  • Frusturated Aug 10, 2008
    I noticed the suggested solution isn't really all that much of one. My camera was completely fine. I had taken pictures with it just recently. The last thing I remember doing is charging the battery like usual. The other day me and a group of friends were gonna head on over to the beach and I thought 'I should bring my camera!' I went to go grab it and when I went to turn it on it started to try and focus itself whilst the screen remained black with the sole message of 'access'. It then proceeded to act like it was possessed and eventually ave me some **** about 'turn off and the turn on again'. I did so...for about an hour in hopes it would actually do something.
    I've tried everything I can think of; hooking it up to the computer; taking the memory card in and out, along with the battery..EVERYTHING!
    Please help! I don't have the money for repair or a new camera right now, and I prefer the one I -already payed for- any way.
  • Anonymous Aug 11, 2008
    Same problem.
  • MARCYMARTIN Dec 29, 2008
    SAME THING HAPPENED TO ME. CAMERA WAS WORKING PERFECTLY ONE DAY AND THE NEXT DAY IT WAS POSSESSED. THE LENS KEPT GOING IN AND OUT BY ITSELF, THE LENS COVER WOULD NOT OPEN AND SHUT AUTOMATICALLY AND THEN I GET A STUPID MESSAGE THAT SAYS TURN CAMERA ON AND OFF WHICH I DID FOR THREE DAYS. NO HELP AT ALL. I THINK THIS PROBLEM IS COMMON TO THIS CAMERA. ALTHOUGH I LOVE THE CAMERA, I THINK IT HAS A VERY SHORT LIFE. MINE IS ONLY 2 YEARS OLD.
  • fiyas_kollam Dec 30, 2008
    Pls Help Me my Camera Is Power on and "access" and 'power off and on again'. Fiyas(9995540040)
  • vpg3 Dec 30, 2008
    I used the camera earlier today, but later the screen showed 'access' when turned on, and the lens moved by itself, after which a message was displayed asking me to turn it off and then restart. The suggested solution has made no difference. Colin
Ok I haven't tried this yet because my camera is at home, but I have the same problem mentioned. I contacted a sony tech online and here is the conversation. I hope this works!SONY: Please try resetting the Camera.To reset the Camera, remove the battery pack from the Camera and then press and hold the POWER BUTTON of the Camera for 30 seconds and then reinsert the battery pack after 1 minute and check if the Camera works normally.K:Ok- So what if this doesn't work?I'm at work now and my camera is at home, I plan on trying it when I get backSONY: After performing the above steps, please press the MENU button on the Camera to check whether you are able to access the MENU items on the Camera. If you are able to access the menu items on the Camera, please try initializing the Camera. Please perform the below mentioned steps to initialize the Camera. First, please press the MENU button to display the Menu screen in the Camera.Using the Control buttons, please select SETUP menu. Then, in the SETUP menu, please select SETUP 1 menu. Now, please select INITIALIZE option under the SETUP 1 menu of the Camera and set it to OK.K: Great thanks! So what happens if I can't access the menu?SONY: After removing and re-inserting the battery, the issue should be resolved and you must be able to access the MENU items on the Camera. If the issue still doesn't resolve, please feel free to contact us.
Posted on Aug 11, 2008
This same thing happened to me a few weeks ago
i looked at some suggestions and people said i should try tapping the lense as it comes out- didn't work, so i basically gave up. But then i tried it just one time today, a few weeks later, and now its working! just keep tapping the lense as it says access to spring the springy things in place.
  • 24 Answers
The lens block is not working properly it has to rebuilt the poles of the front rings that moves in second ring or might be the gear damaged i have the resolve the promlems a lot u can send to me in india or visit at www.omaxphoto.com for parts
I DONT KNOW WHAT TO DO I LOVE MY CAMERA I ACCIDENTLLY DROPPED IT AND NOW THE LENS WOUNT GO BACK IN MAYBE BECAUSE IT FELL FACE FIRST AN THE GROUNG
Posted on Dec 27, 2007
Is it worth paying sony to replace lens block assembly on dsc-w5, 6yrs old, or buy a new camera?When I tirn on camera message says turn on & off again, which I do but does not help. Lens moves back...
Replacement of the lens will cost more than the camera is worth. Try these solutions at the following website before deciding to buy a new camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 23, 2011 | Sony Cyber-Shot DSC-W5 Digital Camera
I have Canon powershot SD1300IS, IXUS 105, digital camera When I try to turn it on, it says: "lens erroe will shut down automatically restart canera" Please help me fix it! I'm going abroad...
So when its stuck you just push on the lens.
i know it sounds crazy, and it'll sound like you cracked it, but it really does unjam your camera!
try it!
Aug 23, 2010 | Canon PowerShot SD1300 IS IXUS 105...
Cannot auto focus
It sounds like the circuit board flex has gone bad, It folds back and forth when you zoom the lens, And needs to be replaced by a repair shop and readjusted. Tony
May 26, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
My sony dsc h 50 camera lens keeps going back and forth
Your camera is trying to get your lens to respond the way it should. If the lens is faulty it will keep going in and out. Your only option is to repair the camera by Sony or local camera repair center.
Jul 02, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
I dropped my camera while it was on and the lens was extended. And I dropped it right on the lens. And now when I turn the camra off, the lens does not go back inside the camera. Everything else is fine,...
if the cams making grinding or crunching noise the lens housing gears are broke. repair usually not very economical. about 80% the cost of cam when you bought it.
Jun 04, 2009 | Casio Exilim EX-Z57 Digital Camera
Digital Camera Fault
ACCESS error could happen when lens gets stuck but if it happens when lens moves back and forth without problem it usually means that where the lens assembly plugs into main system board connection is loose. These connections are held in place by a very small thin fragile plastic clip and a few drops could be enough to snap it but not do any other noticeable damage to camera. Camera would need to be opened to see if clip is broken or maybe cable just needs to me reinserted. Either way only open camera if no longer under warranty and you are somewhat handy
Mar 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot 10.1 DSC-N2
DSC N2 :The switch off switch on and "Accessing" message with the beeping was so annoying. As the lens came out, I held it in place and turned the camera off, I could feel the motoor pulling (three times ) and gently resisted the retraction. the camera turned off with the lens out. When I turned it on the problem was resolved (hopefully permanently). €z
Dec 21, 2007 | Sony Cyber-shot DSC-N2 Digital Camera
Hey, is not working
try hitting the camera against your hand a couple times. sounds crazy but it actually works.
Nov 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
258 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
