Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Vista: No internet after update
Ok, so my cousin installed new updates via windows update. And now IE 7, 8 and firefox cannot connect to any host, including the router.
The connect is wireless, and its vista home premium.
I can ping google fine in cmd.
I can use system restore, and it does fix the problem, but that leaves the os out of date.
Any ideas?
  • 1 more comment
  • adam_g_001 Jun 22, 2009
    I checked the proxy settings, all fine (none set).
    Not even msn connects, it reports an error on key ports.
    I tried disabling the firewall and avg, no help there.
    I also reset IE settings, as well as the add-ons.
    So there is a connection if ping works. It's not the router, as this laptop is under the same network.
    I had this problem before with another pc, for a over a year.
    I phoned out support only a month ago, they said install the updates and report back. I installed them, then every was ok, which was odd.
    There were loads, about 30, all for different products.
    I restore the pc back to the buy date, then installed the updates again.
    This date was around March.
  • adam_g_001 Jun 24, 2009
    Any Ideas...
Perhaps your gateway has changed? Look in your network connections, or perhaps a proxy has been entered into the browser?
Posted on Jun 22, 2009
  • compact72 Jun 22, 2009
    What update was it? Can you remember the install date?
SOURCE:
'Bootloader' is unidentified - Facebook login screen loads with out graphics (ie text only) and takes about 3 minutes. Message bottom left "done with errors" - details varried but mostly...
Open the Chrome and clear cache and browsing data options, Ctrl + Shift + Delete.
Open a new window in Incognito mode, Ctrl + Shift + n, check for unwanted extensions enabled and check for chrome updates (settings - > help -> check for updates)
Apr 07, 2017 | Microsoft Internet Explorer 8
Cant play sound it keeps asking for multimedia audio controller when i install audio driver it states RPC Server not found
It sounds like you have the wrong driver installed or there are more drivers that you need to install and update.
One way to ensure that you install the correct drivers is to go through the Device Manager and update your driver.
This is for a Windows XP system
To Update your drivers through Device Manager, pls do the following:
1. Attach your computer to the internet, make sure you can get on the internet by launching your browser, ie. Internet Explorer, Firefox, Safari
2. Navigate to Start/Control Panel, System
3. Choose the Hardware Tab and click Device Manager
4. See if there are yellow exclamation marks or question marks listed
5. Select them and right click on each one (you have to do this one by one until you see no more yellow exclamation marks or question marks)
6. Choose Update Driver
7. Follow the prompts to complete (usually by clicking ok to all the prompts)
This is for a Windows Vista or Windows 7 system
1. Connect your computer to the internet and ensure that you have internet connection by launching your browser and surfing to your favorite website.
2. Navigate Start/Control Panel/System
3. On the top left hand corner, click Device Manager
4. Do the same from 5-7 under the Windows XP directions up above.
Again, remember that sometimes drivers are related to something else on the system. Therefore you may need to update one or more drivers. This is the only way to ensure that you get everything.
Let me know how it works out and please don't forget to rate me.
Mar 19, 2010 | Compaq Evo D500 PC Desktop
I have the vista system and IE dosent show up in add remove files, I have downloaded firefox. How would I go on to uninstall IE? PS. venexcsd Said it was posible and it depended on the above information,...
Hello.
Welcome to Fixya.
If you want to knw how To Uninstall Internet Explorer 8 on Windows Vista Follow these steps: loadTOCNode(3, 'resolution'
  1. Close all programs.
  2. Click Start, and then click Control Panel.
  3. Click Uninstall a Program under the Programs category
  4. In the Tasks pane, click View installed updates.
  5. In the list of installed updates, double-click Windows Internet Explorer 8.
  6. In the Uninstall an update dialog box, click Yes.
Note If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
7. Follow the instructions to uninstall Internet Explorer 8.
8 . When the uninstall program is finished, restart your computer.
Good Luck^^
Nov 02, 2009 | Acer Aspire 5920-6727 Notebook
I have a 64 bit HP pavilion with vista home premium. When the latest automatic update occured, it shut down Internet Explorer. In order to access the web I did a system recovery and shut off the automatic...
Remove the update the caused the problem in add remove programs, then update manually, or turn off auto update. You can also install and use firefox instead of IE or try doing a repair to IE. Usually IE updates to version 8 and it has problems - version 7 works fine. Uninstalling 8 changes it back to 7. Version 8 will not download properly on a lot of sites - they changed it so U have to use Windows explorer instead to download from FTP sites, and it will not connect to some sites due to all of the security they installed. You could try using default settings on security and turn off filters to see if that works. When windows updates IE it automatically changes to high security.
Oct 02, 2009 | HP KQ495AA Pavilion A6500F Desktop PC
I cannot browse the internet with IE
Ok, could be quite simple or more complicated difficult to know at the moment
first its a good idea to check that you can actually connect to sites
if you can then its more likely a problem with explorer
click the start button, then click "run" when the dialouge box appears type "cmd"
A black window should appear type "ping google.com"
C:\Documents and Settings\Nick>ping google.com
Pinging google.com [72.14.207.99] with 32 bytes of data:
Reply from 72.14.207.99: bytes=32 time=95ms TTL=234
Reply from 72.14.207.99: bytes=32 time=93ms TTL=234
Reply from 72.14.207.99: bytes=32 time=98ms TTL=234
Ping statistics for 72.14.207.99:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 93ms, Maximum = 98ms, Average = 95ms
does this appear? Next it would help to know how you connect to the internet i,e wirless router? Which operating system do you use , vista , xp etc ? Which version of internet explore are you using? And also what updates did you install recently was it a service pack update if so was it sp1 or sp2 etc as there are some known issues with update and internet connectivity
see http://support.microsoft.com/kb/331906
Another potentialy simple soloution might be to to download another browser like "firefox" from another computer put it on a usb stick and the transfer to your pc, install firefox onto your pc and see if it allows you to connect to websites
http://www.mozilla-europe.org/en/firefox/
good luck, would like to know how it turns out
Jun 29, 2009 | Microsoft Internet Explorer 7
Internet explorer
Go to the Microsoft Update site and Download and Install all the necessary updates there are for your PC, they are crucial. link below... windowsupdate.microsoft.com/ As well as doing that.. then, go to the Microsoft Downloads site and download Internet Explorer Seven (7) Install this and this all may fix your current problem. link below..... www.microsoft.com/windows/downloads/ie/getitnow.mspx
Sep 04, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
287 people viewed this question
Top Microsoft Computers & Internet Experts
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
