Question about Sport & Outdoor - Others
I have ordered a service manual for my older model Suzuki DT16 outboard motor, where is the water discharge located, I don't see any water coming out ?
Scooters875 I'm looking for a part for my 16hp Suzuki. Please email me at ishootlive@yahoo.com you you still have this motor. my name is Cory. Thank you
Posted on Oct 31, 2012
I've got a 1981 DT16 with a broken starter pinion. Did you solve your problem? Mine is for sale with very low hours.
Posted on Aug 03, 2009
  • scooters875 Aug 03, 2009
    If you find the little hole where the water comes out.. just carefully stick a little wire up there as usually it's plugged with algae and other dirt. Happens all the time. I've even had to take out the rubber hose and clean it out with a long wire. I'm in NE Montana and don't use my DT16 anymore as I now have a Johnson 8 4 stroke for trolling. That little pinion cog that's broken is the cog that engages the fly-wheel when you pull the rope. I'm unable to find a replacement. Let me know if you need another engine for parts. thanks... Scooter
I need an owners manual for an Evinrude 2 HP outboard motor model 2402E.
http://shop.evinrude.com/category/342499/Literature?brand=27153&horsepower=6955&year=27400&n=0&x=21&y=20
For Evinrude service manuals or Evinrude Johnson owners manuals for 1999 models and prior, please contact the Ken Cook Company at (414) 466-6060 or click here to be directed to their website Antique Literature. On older literature, original printed copies may no longer be available. When this occurs, an effort will be made to fulfill your order with a machine copy reproduced from a master file.
This says it is 1974
https://www.marineengine.com/manuals/evinrude/#e2hp
http://www.ebay.com/itm/1980-2hp-Johnson-Outboard-Repair-Manual-Evinrude-2-HP-/190470229931
Original outboard product and service manuals for Johnson Evinrude Gale...
Aug 07, 2016 | Boating
I need a manual for my 4 stroke 100HP Susuki outboard
Frans, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
suzuki 100 hp outboard specifications Google Search
Suzuki
https://www.tradebit.com/filedetail.php/142965517-suzuki-outboard-service-manual-df90-100-115
May 02, 2016 | Boating
My question is about a suzuki outboard motor not a washing machine
PDF]Suzuki Outboards Workshop Manual - Manuals ...
www.motoren.ath.cx/outboard/suzuki-outboards-workshop-manual-1.pdf
This manual covers the topics that a factory service manual (designed for ..... include rudders, brackets, outboard motors, outdrives, diving platforms, or.
Oct 07, 2015 | Boating
Where are the serial numbers located on a 1985 Suzuki 115 hp outboard motor??? have looked everywhere
The serial numbers are on the transom bracket where your engine bolts to the back of your boat !
If no numbers then remove the gearbox and take the impellor and its housing to a dealer and they should be able to match them !
Feb 23, 2015 | Suzuki Boating
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
Sport & Outdoor - Others Logo
229 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
