Question about Singer Quantum XL-6000 Computerized Sewing Machine
Was in the middle of embroidering and it just froze up and stopped sewing, thought maybe it was just to over worked cause I begun to smell something so shut it down in hopes that in the morning it would be cooled down and be fine, but today the embroidery unit will not move. Any suggestions...............help
I had the same problem happen to me. I had the machine serviced twice already - but I embroider a whole lot. One of the problem is that your machine needs to be oiled, and the other problem - which seems to be a major flaw, when the automatic bobbin winds, it sometimes winds the thread around the bobbin cup (the metal part where the plastic cup sits in to hold the bobbin). When this happens, the machine start to make almost like a swooshing sound and then it stops working. I can't even raise the needle. Check if that is the problem, then you have to take the embroidery scissors and cut the thread and then carefully pull it out with the tweezers. It's time consuming and frustrating but it can be done. Please check your machine about the thread and let me know.
Posted on Jul 26, 2009
My Elisimo keeps stopping in the middle of an embroidery, red light on, presses foot lifter locked, sits for a minute or so and then green light comes on and i can continue embroidering. Is it board?
may be the safety device activating if it hasn't been oiled in a while. Make sure the area around the machine and embroidery arm is free of anything that could hit it and cause it to stop or strain.
Nov 30, 2016 | Sewing Machines
How to deactivate the safety device on the Singer Futura SES 1000 embroidery machine? How can I get the hand wheel to turn again to get the machine to sew/embroider?
You can't--something is stopping the wheel from turning, and until you find out what is stopping it, your machine will be locked up. Take a look below the bobbin case, and you'll see a ***** holding a little door. It allows you to clean and see on the other side of the bobbin basket. Chances are, there's something like a broken off needle stopping the gear that turns the hook. It can also be caused by threads wrapped around the tension disks, or around the inside of the hand wheel itself. The hand wheel can be removed by removing the cap in the center--it is hiding a ***** that holds the wheel.
Feb 29, 2016 | Singer Sewing Machines
Why is my bobbin thread is showing while embroidering
Your tension on top can be loosened. If this causes your stitch to be too loose then tighten your bobbin tension. Just think of the top and bottom tensions as a tug of war. They must be even to get the stitch in the middle of the material.
Jul 31, 2014 | Baby Lock Sewing Machines
My Janome 10000 stopped in middle of embroidering a design and the machine rebooted. it was making a bit of a whining sound as it was stitching just at the last..but now the hand wheel seems harder to...
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Nov 29, 2009 | Janome Memory Craft 10000
My start/stop switch will not begin sewing
Is the problem with embroidery only? If with both sewing and embroidery function and there is no error code (just 00) on the display, my wife experienced the same problem. There was an internal sensor that was bad. The sewing machine shop repaired with a new Singer part. Part was about $20, labor was $180.
Dec 23, 2008 | Singer CE-200 Quantum Futura Computerized...
Machine stopped running, its getting power but wont run.
Are you sewing or embroidering? If you are embroidering, the machine automatically stops and shows scissors in the window, for you clip the jumpstitch. Then just push the "Run/Stop" button.
Dec 13, 2008 | Husqvarna Rose
Machine running slow then just stopped
Grand Lake Sew and Vac does not repair sewing machines. They send them to a repair place in Alameda. Someone comes to pick up the broken machines every Tuesday. Repairs are not timely and can be pricey,
Jun 22, 2008 | Euro-Pro Shark 80 - 7133
Thread get's tangled and attached to plate while embroidering
Just a thought. Is it possible that your thread is wrapping around your spool post or snagging on your thread spool?
sewman7
Jun 09, 2008 | Bernina Artista 180
MY machine has never worked perfet liked I hoped it would. When I embroider the top thread ends up all lose and
This could be caused by many things but I would suggest that you take the machine to your local dealer for them to have a look at as the bobbin case may be the problem and they may have to replace it. If you look at the bobbin case it should be smooth all the way around - if there's rough edges then that could cause a problem. Also if the bobbin case jumps out of the socket then this is a good indication that you need to have it replaced.
Apr 26, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Quantum XL-6000 Computerized Sewing Machine Logo
215 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
