Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Air bubble in yellow ink line of a Brother MFC-240C
I have had my Brother MFC-240C printer for two years now and have never had a problem with it. Yesterday on a whim I decided to refill the yellow cartridge myself instead of purchasing an already filled cartridge. After doing this, the ink wouldn't come out. I tried the cleaning cycle but still no luck. I then purchased a new yellow cartridge, figuring this would cure it. The ink still won't come out. I noticed the plastic tube lines that hold the ink. In the yellow tube line are air bubbles. Is there a way to remove them, or is my printer a lost cause? Thanks, Abbynm
  • 1 more comment
  • abbynm Jun 26, 2009
    Can you explain further how to remove the print head? I started a print head cleaning and unplugged the printer to move the print head to the middle. I don't see the loop you were referring to. Also, are the ink tanks under the print head or is this in the area where the cartridges are? Sorry, the only thing I have ever had to do with this printer is unjam paper and change the ink cartridges. abbynm
    After running numerous cleaning cycles, it looks like the air bubble is out of the ink line. However, the yellow ink still won't print. Besides running the test print pages after the cleaning cycles, I also ran off about 20 pages just using yellow ink. Any suggestions at this point? Thanks, abbynm
    Can you please explain how to take the print head out? I have tried all the other suggestions that were given, but the yellow ink still doesn't want to come out. Thanks, abbynm
    Top Expert:
  • Brother Master
  • 81,285 Answers
With cost the cost of new printers so low why even fix this one, the cost to fix it will exceed the cost of a new one, that I am sure of 100% have allot of previous experience to support this statement as true..
Posted on Jun 27, 2009
    Sergeant:
    Champion:
  • 233 Answers
Yes, try taking them off.
But i think refilling those cartridges werent a good idea... :(
I just hope you didnt damage anything.
Try shaking them up and put it in again. I have the same printer and i did that and it worked!!
If not you can try asking the brother repairing to get a pro to check it out (if it doesn't work).
Good luck!!
Posted on Jun 26, 2009
    President:
  • 2,187 Answers
Below is the recommended steps in cleaning the print head from the manufacturer: The unit may be slightly different but should have the same basic components.
Cleaning the Print Head
  1. Press the Ink, Ink/Reports, Ink Management/Reports or Ink Management key.
  2. Use the up or down navigation key to select CLEANING.
  3. Press Menu/Set to confirm your choice.
  4. Use the up or down navigation key to select the color that is not printing
    -OR-
    Select ALL if more than one color is not printing.
  5. Press Menu/Set to confirm you choice.
  6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
  7. Test by printing the "Print Quality Check Sheet":
    2. Use the up or down navigation key to select TEST PRINT.
    4. Use the up or down navigation key to select PRINT QUALITY.
    5. Press Menu/Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
Source: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000700/000035/faq000735_001.html?reg=us&c=us&lang=en&prod=mfc3240c_all
    Genius:
  • 1,847 Answers
Take the Print head out
Then blow compressed air thru the holes in the bottoms of the printhead there are 4 of them you will be able to figure out which hole goes to which color by watching the ink bubble out the other side.
Basically first remove the ink tanks. Then notice on either side of the carrier you will see a little loop. Note that it is the end of a 3 inch wire. Push it slightly down and then to the side away from the carrier until past the posts. This will free the print head and you can roll the print head out.
In one of the other posts, they mention putting 1/8th inch of alcohol in a dish (disposable or not valuable) and then placing the printhead in it and pouring a little more alcohol in the hole, emptying the dish when necessary to make sure that alcohol doesn't get to the electronic connections in the back. Then dry excess, put back in, install ink tanks and print about 20 pages to get the alcohol out.
Another post said instead of alcohol, just soak the bottom of the print cartridge in a dish in water overnight (again not high enough for the electric contacts to get wet) and then reinstall.
thanks
Kevin
Posted on Jun 25, 2009
My brother mc 240c print in yellow but not black? It connected to my laptop throw usb connection.
Clean the print heads and then make sure the drivers you installed recognize all of the ink cartridges ar their proper ink levels. Replace ink if necessary.
Aug 24, 2011 | Brother Multi-Function Center MFC-240C...
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
Cant print anything after replacing ink cartidges for brother 240c
If the printer has been sitting without use for a long time you may need a new printhead, if you just changed inks it could be just an air bubble in the ink tubes. If after several cleaning cycles you don't see any improvement, it's the printhead and not just a bubble.
Feb 22, 2010 | Brother Multi-Function Center MFC-240C...
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
HELP ON MFC-240C
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Sep 01, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240c
Best generic ink(in carts) comes from skyhorse:
http://www.inkhouse.cn/en/
Its better than the original ink!!!!
Search your country for resellers by help of google or ebay.
Jun 10, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-240C
you might try a head cleaning and re calibration exercise first.
May 25, 2008 | Brother Multi-Function Center MFC-240C...
Clean unable
Follow this LINK and rate me when you are done pls
May 02, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
259 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
